head gasket leak
- CTSZ1
head gasket leak
23 Mar 2006 05:21
On this '76 900cc motor I have a head gasket leak at the #4 exhaust area. The motor set for several years. I am assuming that leak can only be repaired by replacing the gasket. My dim hope is that maybe it can be cured by resetting the torque on the head bolts. What says you?
Thanks
Thanks
- lemo32
- The Price of Cool aint cheap
Re: head gasket leak
23 Mar 2006 15:05
what brought you to the conclusion it was a leaking
head gasket?
head gasket?
1979 kz 1000 06 katana 750
- CTSZ1
23 Mar 2006 15:12
oil is starting from the area immediately under the #4 exhaust port and then being blown around the right side of the block. Valve cover is not leaking, and cam plug on that side isn't leaking.
Any ideas?
Thanks
Any ideas?
Thanks
- lemo32
23 Mar 2006 15:17
is there any smoke coming from exaust?
- wireman
23 Mar 2006 15:18
as my man always says:its already broke,ya cant hurt it any!torque away young man,torque away.:whistle: goodluck,happy wrenching!
- CTSZ1
23 Mar 2006 15:45
lemo32, No smoke and plug isn't oil fouled.
Wireman, that's my temptation, I've got to check the valve clearances anyway, so while the cam cover is off....:whistle:
thanks
Post edited by: CTSZ1, at: 2006/03/23 18:46
thanks
- lemo32
23 Mar 2006 15:54
sounds like your in for fun. pulling a head isnt that bad. if you need a head gasket let me know i happen to have a kz 900 two piece with oring i would let go cheap
or call wiseco, went from a two piece two a one piece
for about 42.00. with a high milage motor you need to check compression it may be time for a total rebuild.
