82 kz1000ltd clutch cable issues
28 Nov 2009 10:03 - 30 Nov 2009 00:09 #336276 by knibbeone
82 kz1000ltd clutch cable issues was created by knibbeone
Hi there, I just purchased a 82 KZ, removed the clutch cable from the lever so I could install a Vetter fairing, all went well until I tried to put the cable back on the lever. It is 2 inches too short now. I can find nothing in the Clymer manual I just purchased about cable replacement. Do I need to pull the whole cover off the left side? Is there gaskets involved? Thanks for any advice. Too broke to go to a shop. David
1982 KZ1000 LTD
Last edit: 30 Nov 2009 00:09 by knibbeone.
28 Nov 2009 10:42 #336280 by Vter Bob
Replied by Vter Bob on topic 82 kz100ltd clutch cable issues
Hello David, welcome to KZ Land!
I would venture to guess that you may have routed the cable differently and that accounts for it now seeming to be to short. As far as removing the sprocket cover, there are no gaskets you need to worry about. There are however a few other things you will have to remove first. Peg mounting bracket, shifter lever and starter motor cover (this has a gasket but is a heavy rubber one which is re-useable) Under this cover the opposite end of the clutch cable attaches to the mechanism the actuates the clutch push rod. The cable end is held in place with a small cotter pin. If the pin is broken or missing the cable end could have slipped from the holder. This also could be the cause of the cable seeming to be to short. If you don't have a Factory Service Manual (aka the KZ Bible) check here in the archives as I believe there is one available for download. If not send me a PM with an address and I'll send you one on CD.
PS: Not a lot of guys here are fans of the Vetter fairing but I love them. Have one on my 550 and it makes riding a lot more enjoyable to me.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
28 Nov 2009 10:59 #336284 by MFolks
Replied by MFolks on topic 82 kz100ltd clutch cable issues
While the sprocket cover is off, clean and re-lube the clutch rod mechanism (where the clutch cable attaches)and clean the build up of chain lube from the push rod.
29 Nov 2009 22:59 - 30 Nov 2009 00:09 #336658 by knibbeone
Replied by knibbeone on topic 82 kz1000ltd clutch cable issues
Thanks for all the help guys, i pulled the side cover, cleaned everything up and got the cable hooked up as it was before. Only now, it feels like it wants to start rolling even with the clutch in. It never did that before. I tried adjusting, that made no difference. Any suggestions?
1982 KZ1000 LTD
30 Nov 2009 04:08 #336662 by roy-b-boy-b
Replied by roy-b-boy-b on topic 82 kz1000ltd clutch cable issues
Adjust it either on the handlebar or in the middle of the cable if you are near the end of adjustment on the handle bars. Roy
30 Nov 2009 08:05 #336679 by knibbeone
I am nowhere near the end of adjustment, thats whats troubling. Is it new clutch time? The bike only has 10k on it. Before i put the fairing on, it was fine for the short time I rode it. I just purchased this bike and dont know much about it. Thanks, David
1982 KZ1000 LTD
30 Nov 2009 08:18 #336683 by timebomb33
Replied by timebomb33 on topic 82 kz1000ltd clutch cable issues
you will need to make your adjustments at the main adjuster first not at the cable save both the adjusters on the cable for last.those are for fine adjustment only. back the cable off first before you adjust the main adjuster.
I THINK MY POWERBAND BROKE
