Ummm... Guess I have super strength... Whoops!
  • cricketfire46
  • Topic Author
27 Nov 2009 23:00 #336222 by cricketfire46
Ummm... Guess I have super strength... Whoops! was created by cricketfire46
In the process of doing some repairs I decided it would be easier to just take the exhaust off to get to the oil pan bolts easier. That was a great idea, until I snapped an exhaust stud. Decided to go ahead and put helicoils in since the studs felt rather loose. After getting all the holes drilled out, and re-tapped I kinda sorta screwed up. Some how (after putting a bolt on to keep from "over tapping") I still ended up trying to tap the solid aluminum in the bottom of the hole. Pulled the motor, and have managed to finish everything but the top hole on #4. Have tried to weld nut to tap, use drill press, hand drill, and even melt out the tap with no luck. I already have a nice "sleeve" from the broken clutch. It is the same size and thread pattern as the rest of the stud holes. Can I just cut the existing hole all the way off with a cut-off wheel and dremel and get someone to weld the new sleeve in? or do I need to keep snapping bits trying to drill it out???
83 kz750 ltd, dyna coils, k&n, mac 4->1 just rolled 50k
  • txturbo
  • Ex-Kawasaki Mechanic 1981-1985
28 Nov 2009 05:58 #336240 by txturbo
Ok..this post is confusing.You broke off a tap in an exhaust stud hole and you are trying to get it out....I got that part.I have no idea what the clutch sleeve and the "cut off the nut" have to do with it. But....trying to drill out a broken tap isn't possible. Taps are way harder than drill bits.Either you will break the bit or end up drilling out more aluminumm before you even scratch a tap.Best thing to do now is take the head to a machine shop and see if they can fix it.
1984 ZX750 E1 GPz Turbo
1984 ZX1100 A2 GPz
1984 ZX900
1996 KZ1000P Police bike
1970 Honda CT 70H 4sp manual
1965 Honda Dream 305
2003 Honda Shadow 1100
1971 Suzuki MT50 Trailhopper
1969 Camaro SS
1966 Impala
1966 Impala SS 427/4spd
28 Nov 2009 06:37 #336246 by Old Man Rock
Replied by Old Man Rock on topic Ummm... Guess I have super strength... Whoops!
Take it to a machinist and pray they can repair correctly...;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
28 Nov 2009 07:46 #336257 by timebomb33
Replied by timebomb33 on topic Ummm... Guess I have super strength... Whoops!
if any of the tap is sticking out of the put a bit bigger nut overr the top of it and then weld the nut to the tap it should come out fairly easy then.turn it back out just like a bolt
I THINK MY POWERBAND BROKE
  • unomike
  • Biker for 40 years.
28 Nov 2009 08:40 #336263 by unomike
Go to this website, they have a page that deals with removing broken taps. I used to work in a machine shop and we used a method that used an electrode to burn out the taps. You may find a full service machine shop that has the machine to do this. It will save your part.
www.americanmachinist.com/304/rss/Article/False/83882/
Own: 1980 Kaw KZ1300,Stage 1 kit,K&N pods
1972 Harley Davidson XHL Sportster, 1972 Suzuki T500, 1974 Hodaka 125 Dirt Squirt, 1980 Honda 250 VTR, 1983 Yamaha 750 seca and a 1974 yamaha GT80 for my son.
Bristol, Tennessee. USA
28 Nov 2009 08:53 #336266 by PLUMMEN
if you can somehow get a hole bored into the tap the end of of a chainsaw file where handle normally goes can sometimes be used as an easy out B)
  • cricketfire46
  • Topic Author
28 Nov 2009 11:05 #336285 by cricketfire46
Replied by cricketfire46 on topic Ummm... Guess I have super strength... Whoops!
Sorry, was a little tired when writing this. This whole project started to change the starter clutch. In the process I broke a female end of one of the fingers on the clutch hub. This is where the extra part is from. I called it a sleeve because I didnt know a better way to describe it.
  • cricketfire46
  • Topic Author
28 Nov 2009 11:09 #336286 by cricketfire46
I will try the welding trick again. When I tried this with the exhaust stud, I couldnt get a good bead. Using a 110 mig. Probably didnt find that sweet spot with wire speed and voltage. I was getting great welds on the nut, but couldnt get very good bead on the stud. What would the ideal heat and wire speed be to get good bead on the TAP?
28 Nov 2009 11:24 #336288 by JMKZHI
No help on the welding & this might not matter now, but you might've been able to install 8mm studs (the stock exhaust studs are 6mm).
  • unomike
28 Nov 2009 13:22 #336295 by unomike
If possible submit a picture of the broken tap. We might be able to give you a better solution.
  • cricketfire46
  • Topic Author
28 Nov 2009 14:16 #336312 by cricketfire46
that was what i planned on doing, and that would be where the broken tap came from. I will work on getting a pic up when I get home. Without having a pic I can explain that the original hole is now bored out and makes an inward cone to the motor. The small end is on the motor side, and the larger side is on the exhaust side. There is some melted aluminum around it from the fouled attempt with the hot wrench.
