Oil Cooler, should I remove it?
  • Qdude
  • Topic Author
  • It is all good.
24 Nov 2009 22:17 - 24 Nov 2009 22:37 #335787 by Qdude
Oil Cooler, should I remove it? was created by Qdude
New purchase came with Oil Cooler.
I don't have plugs for oil ports.
Should I search for the plugs and get rid of the Oil Cooler, or should I just leave it on?
The bike is down to the frame right now.
77 KZ 650 C1.
77 KZ 650 C1.
Last edit: 24 Nov 2009 22:37 by Qdude.
25 Nov 2009 02:27 #335797 by Old Man Rock
Replied by Old Man Rock on topic Oil Cooler, should I remove it?
Seattle Washington... Most likely won't require due to outside temps not reaching 100* plus...
Same time, also depends on your engine build. Higher compressions, performance engines will run a tad hotter...
You can always add it on later outside of that, your call really...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
25 Nov 2009 06:17 #335833 by Jeff.Saunders
Replied by Jeff.Saunders on topic Oil Cooler, should I remove it?
The key is what you put in the engine, and how you plan on riding the bike.
Oil coolers can overcool the engine. If you have a high compression engine that runs hot, then the oil coolers can make sense. But with a stock engine run for only 20-30 miles at a time, there's really no benefit, and a ton of negatives in running an oil cooler in a cooler region like Washington state.
Your engine needs to come up to full operating temperature to burn off any condensation that accumulates in the engine. On bikes that are ridden for short trips, it's not unusual to get that milky white oil from the condensation inside the engine cases.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • TeK9iNe
  • What did you do!?!
25 Nov 2009 08:54 - 25 Nov 2009 09:03 #335855 by TeK9iNe
Replied by TeK9iNe on topic Oil Cooler, should I remove it?
High temp Therm -o- stat.
Oil temp gauge...
just a thought.
:laugh:
These are from American Classix
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 25 Nov 2009 09:03 by TeK9iNe.
  • hugo
  • '92 Zephyr 750
25 Nov 2009 10:00 - 25 Nov 2009 10:31 #335863 by hugo
Replied by hugo on topic Oil Cooler, should I remove it?
In the 70's, air cooled fours japanese bikes imported to the US did not have oil coolers, but same bikes going to Europe had them.
I have a 91' 750 Zephyr and it came with a big oil cooler from factory. All Zephyrs had them, and any air cooled 4 cyl retro Japan may build today, would come with one. Even liquid cooled bikes have them. Most you don't see because is a coolant coil buried around the oil filter base. Suzies SV1000 or GXS-R1000 have conventional in front of oil filter. It is better to have it than not.
The oil cooler is not intended for cooling the engine, it is intended to prevent the oils from getting too hot, like in stop and go condition that requires slipping the wet clutch a lot. The oil cooler would not slow the warming up from cold start, as it does not have any telling effect, until bike is moving.
Last edit: 25 Nov 2009 10:31 by hugo.
25 Nov 2009 10:26 #335866 by timebomb33
Replied by timebomb33 on topic Oil Cooler, should I remove it?
you have 2 choices leave it on or sell that nasty thing to me really cheap. i'd keep it on the bike it's cheap insurance if you plan on hotrodding your motor.
I THINK MY POWERBAND BROKE
  • Qdude
  • Topic Author
  • It is all good.
25 Nov 2009 10:42 #335869 by Qdude
Replied by Qdude on topic Oil Cooler, should I remove it?
I will go through the box of receipts and find out what has been done/added to this bike by PO. (He loved to tinker, I found three stripped out bolt holes) I imagine that I am going to get rid of the cooler, so I will need to remove the hose nipples and plug up the ports on the engine.
Will this hardware be easy to find?
77 KZ 650 C1.
77 KZ 650 C1.
25 Nov 2009 16:20 #335919 by bountyhunter
Replied by bountyhunter on topic Oil Cooler, should I remove it?
IMHO, oil coolers were a whole lot more necessary in the old days when oils were not so good. Use a top synthetic with a good additive package and you will have no worries. Unless you ride hard in a really hot climate, I can't see the need for an oil cooler.
25 Nov 2009 16:23 #335921 by bountyhunter
From what I read, that condesnation combines with sulphur compounds to make sulfuric acid and can really screw up your engine. The oil has "buffers" in it to neutralize acid but you have to get the oil up to temp. Mechnics tell me the fastest way to destroy an engine is to do the "five minute idle" thing once a week over winter storage because of the condensation/acid formation.
  • 550A2
  • keep the shiny side up
25 Nov 2009 17:54 #335944 by 550A2
Replied by 550A2 on topic Oil Cooler, should I remove it?
id keep it man, the longer you run it the hotter it will get.
the thermostat is a great idea!
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
27 Nov 2009 05:48 - 27 Nov 2009 05:53 #336116 by will61310
Replied by will61310 on topic Oil Cooler, should I remove it?
2 of my bikes came with lockhart coolers w/ thermostats. Do they work? Do they block the flow of oil thru the cooler in colder temps?
...1980 LTD 1000...
Last edit: 27 Nov 2009 05:53 by will61310.
