New Rings
  • KZ1100 Bully
  • Topic Author
24 Nov 2009 17:57 - 24 Nov 2009 18:12 #335707 by KZ1100 Bully
New Rings was created by KZ1100 Bully
Hi,I got a new set of rings to install. One of the rings have what seems to be a lip on the edge. Can some one tell me how to install the rings, where and what side is up. One ring has the little lip around the edge. The first slot or second one
Thanks
1983 Kawasaki KZ1100 Spectre D2
Last edit: 24 Nov 2009 18:12 by KZ1100 Bully.
24 Nov 2009 18:12 #335720 by Kawboy74
Replied by Kawboy74 on topic New Rings
Hi If your rings are KL brand, it seems that the top ring usually has a bevel to it wherin the widest part of the bevel goes to the bottom of the groove. Middle rings typically have a cutout which goes to the top and you may find the letter "N" stamped on the top face. It might pay to check the website of the manufacturer or the people you bought them from. Hope this helps! David
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
  • KZ1100 Bully
  • Topic Author
24 Nov 2009 18:16 #335722 by KZ1100 Bully
Replied by KZ1100 Bully on topic New Rings
I got the rings from Z1. They are npr rings. One ring is is light in color and the other is a black ring with the bevel on it.
24 Nov 2009 18:26 #335725 by Kawboy74
I would call Jeff at Z1 and ask him personally, a wealth of info with this man!
25 Nov 2009 16:28 - 25 Nov 2009 16:28 #335923 by bountyhunter
Replied by bountyhunter on topic New Rings
On my stock rings, only the middle ring has the beveled edge and the edge with the cut goes downward.
Last edit: 25 Nov 2009 16:28 by bountyhunter.
25 Nov 2009 16:51 #335930 by Kawboy74
There have been changes made to even stock rings as my original rings on my '74 had a one piece oil ring and the stock rings I picked up to replace them with had the aftermarket type oil ring made up of the wavy-type pieces. I kinda wish they still had the one-piece type.
