All stock 1978 kz1000, when do they need valve job
  • newOld_kz1000
  • Topic Author
  • FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
22 Nov 2009 22:37 #335295 by newOld_kz1000
Hi folks, when you're out scouting for your next project how many miles do you expect on the odometer of a bike you're looking at before you say 'That many miles means I need to ask the owner if he's ever done a valve job.'
I guess it depends on how hard the bike's been ridden.
Assuming an adult-owned kz1000, late 70s vintage, if you saw 30,000 miles on the odometer would you figure on doing a valve job in your decision on Buy/Not Buy?
Probably not a fair comparision, but cars don't need valve jobs till over 100,000 miles I reckon. However they are water-cooled too.
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
22 Nov 2009 22:57 #335296 by donthekawguy
Replied by donthekawguy on topic All stock 1978 kz1000, when do they need valve job
I would say 30K would be about right. All the bikes I have owned had about 20K and were getting tired with the exception of my 79. It had 25K on it and was as fresh as the day it was born.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
23 Nov 2009 04:54 #335315 by otakar
My 76 900 has 50k on it and it is still fine.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
23 Nov 2009 06:10 #335338 by 650ed
My '77 KZ650C1 has 49,000 miles and it's still fine too. Ed
  • newOld_kz1000
  • Topic Author
23 Nov 2009 08:41 #335358 by newOld_kz1000
Replied by newOld_kz1000 on topic All stock 1978 kz1000, when do they need valve
Guys, thanks for that, I figured that these valve jobs would be odd if they were needed *too* quickly -- the reason is, if you figure 10,000 miles a year driving, that would mean we'd be doing valve jobs on 3-year-old bikes from manufacturers who did pretty fair jobs at design and manufacturing. Japanese cycle and auto designing and manufacturing is unquestionably highly regarded these days.
QUESTION FOR 650ed and otakar:
When you do your valve adjustment checks, is there a way to avoid hit-or-miss when you're doing shim selection for out-of-spec gaps between shim and cam lobe?
What I mean is, with 50,000 miles I suspect you guys have had to do valve adjustments by putting in different shims along the way. And I suspect that you've encountered cam-lobe-to-shim clearances that are less than .05mm, which is the minimum allowed gap.
How do you go about ordering shims efficiently, that is -- when you measure valve clearance and the gap is out of spec on the low side (less than .05mm) how do you know which next shim to choose to install at that valve?
I realize the FSM has the table you use but the table only works if you can read the current gap accurately and I can't do that.
I can't measure an out-of-spec valve clearance below the minimum allowable gap of .05mm because I can't find a feeler gauge that will measure small gaps less than .05mm.
So when choosing the correct smaller shim, how do you guys choose it, if you are unable to know if you have, say, .03mm of clearance, or .02mm of clearance, etc. -- you can't measure that small of a gap without super thin feeler gauges below .04mm which don't seem to exist.
Or are you guys doing a 'hit-or-miss' approach?
I need to do a re-shim on a bunch of 'below-minimum-.05mm-gap' shims on my 1978 kz1000.
I need a bunch of thinner shims because my gaps are worn below the .05mm minimum gap but I don't know if I should order the next size smaller shim, or the next-next smaller shim, etc. so I'm confronted with hit-or-miss shim ordering.
Them shims aint cheap. But I am. :silly:
23 Nov 2009 09:57 #335377 by RonKZ650
Replied by RonKZ650 on topic All stock 1978 kz1000, when do they need valve
I've got 67,000 on the KZ650 I ride most currently and it still runs fine and never had the head off it. Uses zero oil still.
About the shims, all you can do really is take an edjucated guess at size. You measure less than .05mm, try spinning the bucket with your fingers. If it spins you know you have between 0 and .05mm so figure what spec you want to adjust to. Mostly .10-.15mm is good, so if you subtract 2 shim sizes theoretically the clearance on the 0-0.05mm valve would now measure between .10-.15mm right where you want it.
If the bucket does not spin, you have zero clearance and unless someone has recently been fooling with the valves, chances are going down 3 sizes would be the first guess.
  • newOld_kz1000
  • Topic Author
23 Nov 2009 10:19 #335381 by newOld_kz1000
Thanks Ron, excellent advice there, I'm a complete newbie regarding 'correct shim replacement' and the 'spinning the bucket' idea is GREAT.
Thanks.
23 Nov 2009 15:13 - 23 Nov 2009 15:16 #335420 by bountyhunter
Replied by bountyhunter on topic All stock 1978 kz1000, when do they need valve job
The shop that did my first valve job was contracted to service the KZ1000 police bikes and he said their normal interval was about 20k miles. maybe they beat theirs harder than average. Bikes cook the valves and valve seals earlier than cars because air cooled engines have very high temps in the valve areas.
Mine got maybe 45k on the original valves but that was a lot of short city riding in there. Longer typical rides is less stressful on the engine.
Last edit: 23 Nov 2009 15:16 by bountyhunter.
