Tell me I'm wrong
21 Nov 2009 07:31 #334998 by Afrosemite
Tell me I'm wrong was created by Afrosemite
Ok, so I replaced my clutch cable yesterday and apparently routed it poorly. So today I notice that there is a big tear in the sheath, apparently from rubbing against the cylinder lock.... I really really just want to put duct tape on the tear, but I know I should buy a new cable... someone tell me that I need to replace it so I can get it out of my head.
the tear goes all the way to the metal, not the actual inner cable, just the outer metal covering.
\'78 Kz650d sr
21 Nov 2009 07:35 #335001 by 650ed
Replied by 650ed on topic Tell me I'm wrong
The tear may allow water to penetrate the cable (this is bad) but otherwise shouldn't hurt anything other than cosmetics. But if you don't re-route the cable correctly you may cause it to bind. Ed
21 Nov 2009 07:56 - 21 Nov 2009 08:12 #335007 by Old Man Rock
Replied by Old Man Rock on topic Tell me I'm wrong
As long as the tear isn't into the inner sheathing thus preventing smooth cable operations...i.e... the cable is wearing/catching on thew damaged area do the following...
1) Buy a new cable... Z1 has them for under $20...
2) Use E6000 (Black) or some other high temp black RTV over the cut. Once cured, RTV will stay pliable, prevent dirt/water from entering the inner cable and with the high temp protection, should be just fine if contacts the cylinder or engine cases.
Personally speaking, #1 for under $20... No brainer....
That's a big meal & a pack of smokes these days.... :ohmy:
OMR
EDIT: BTW, don;t throw this cable away if you chose option #1, tuck this under the tail section as a spare and carry with you....;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 21 Nov 2009 08:12 by Old Man Rock.
  • Kawickrice
21 Nov 2009 08:12 #335011 by Kawickrice
Replied by Kawickrice on topic Tell me I'm wrong
I use electrical tape for small chaffing plus its black
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
  • newOld_kz1000
  • FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
21 Nov 2009 08:12 #335012 by newOld_kz1000
Replied by newOld_kz1000 on topic Tell me I'm wrong
Use heatshrink. Or, use black electrical tape and heatshrink over the tape.
I'm a rabid cheapskate, your cable's new, I also like fixing things other people throw away (I've made a lot of money buying beaten-down stocks with this attitude) and the heat shrink will cost maybe $2, get it at Home Depot or Lowes or Radio Shack, surely you have some black electrical tape.
Since buying a new cable requires removing this one, seems like you're already removing the current cable anyways.
Remove this one, put on the black electrical tape, slide the $2 worth of black heat-shrink tubing over the tear, use a hair dryer on high or a heat gun, DONE. The heat shrink + black tape will keep it clean and dry. And it will blend right in with the stock black sheathing on that cable.
Remove it, fix it, re-install and route it better.
$2, put the $18 into a beaten-down stock or a CD.
Or some steak and potaters, cook 'em on the grill.
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
21 Nov 2009 10:08 #335039 by MFolks
Replied by MFolks on topic Tell me I'm wrong
Radio Shack or any other electical/electronic supply store sells 1/4" I.D. black spiral wrap tubing. It's slit to wrap around wires/cables and works well as a chafe guard in wear areas on bikes.
Spiral wrap comes in several sizes and can accept many times it's diameter when wrapping wires or cables.
