horsepower with 1075 & 118 web cam
- Ktm181
- Man made it, so Man can fix it
Re: horsepower with 1075 & 118 web cam
16 Nov 2009 17:51
Thanks for your time Larry, have been cruising your site and learning,will write you direct. DO YOU have a recommended head porter down in Australia? Where should I go for CRS29s in the U.S?
Regards,
Kt
Regards,
Kt
- larrycavan
16 Nov 2009 17:55
Ktm181 wrote:
I'll be shipping and entire bike over to Sydney in a few months.
What part of Oz are you in? My wife's brother lives in Woombye Queensland. I've been around WA a bit myself, from Perth, down the coast to Albany, then up through the sheep country back to Perth.
Had a bit of a chat with this resident...
THANKYOU so much for your replies guys, i really appreciate it. I am on a budget, arent we all, i may have to stick to colleting the parts and save some more $$$, i would really like the porting as well so will just have to wait i guess. I would like to send the port work to Larry Cavanagh but am a bit nervous sending a head all the way from Australia, might look into it though or Larry may know someone he would recommend down here, I understand he sells equipment to Australian businesses.
I apologize on the "bodgy" photo, i could not for some reason upload the picture of my bike and i wanted a pic of a similar one so grabbed one from somewhere, will have to try again.
Kt.
- Ktm181
16 Nov 2009 17:59
Good to hear ! Its a wonder he let you get that close for the picture,they are very savage!
I am about 35 miles west of Sydney at the base of the mountains, will you be coming for a ride on the bike you are shipping then???
I am looking into whether feasible to ship a head over to you.
Kt
Kt
- larrycavan
17 Nov 2009 02:49
Ktm181 wrote:
Sudco is the main supplier of Keihin carbs here. Their jetting is always on the rich side. That's why I listed suggested jetting.
Email me larryc@flowbenchtech.com
Larry C
Kt
Larry C
- Old Man Rock
17 Nov 2009 03:58
I obtained my 29 Cr's from Dynoman....
Buzz over there is a straight up guy, he spent about an hour with me on the phone the first time asking me pretty much the same questions Larry had regarding what I had in mind in my build.... Basically seeing if I was just blowing smoke out my ass or not...
Anyhoot, turned out giving me ~ $100 off since I had bought my cams and kerker from them... The jetts I get for half the price of Sudcos...
dynoman.net/carb/keiCR.html
Larry is 100% correct in the pre-jets... They will be on the rich side so pre order 1-2 sizes for leaner operations...
Here in Az, dropped 2 sizes on the mains and slow jets (pilots) and one clip position change 4 to 3 to lean them babies out.... Same as you, hotter than hell here in summers.... Fairly close elevations I would think pending your area, maybe not...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- larrycavan
17 Nov 2009 13:57
otakar wrote:
Good MPH
Wrong cams for the drag strip though.
timebomb33 wrote:my 74 with 110 web cams 29 smooth bores a yosh pipe dyna s ignition 1075 wiseco kit and a self ported head made 114 horse and 79 ft.lbs of tourque the one and only time i dyno'ed it. it is a very good combo that i would recommend highly to anyone it can be as wild as you want it to be or as mild as a mouse very street freindly bike. i also went 10.74 at 123 mph with this combo in the same bike
I had roughly the same #s on my 78 Z1R with Yoshi Bonneville cams, Yoshi series 2 pipe RC Engineering 1105 kit and stock 28s. 10.82 @ 132mph
Good MPH
- otakar
17 Nov 2009 15:46
larrycavan wrote:
I Know Larry, wrong sprocket, too. i never intended it for the strip but did road race it for a couple years back in the late 70s. I still have the beast in my stable.
otakar wrote:timebomb33 wrote:my 74 with 110 web cams 29 smooth bores a yosh pipe dyna s ignition 1075 wiseco kit and a self ported head made 114 horse and 79 ft.lbs of tourque the one and only time i dyno'ed it. it is a very good combo that i would recommend highly to anyone it can be as wild as you want it to be or as mild as a mouse very street freindly bike. i also went 10.74 at 123 mph with this combo in the same bike
Good MPH
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- nads.com
17 Nov 2009 18:08
larrycavan wrote:
Here's my selection for your bike. It's about strong power in the RPM range you ride most with plenty left over to scare yourself with if you want to.
If you're going to have the head off and apart, skip the 118 grind and get the 483 grind instead. You'll have to clearance the tappet bores a little and remove the X's from the valve cover. Get springs too.
A lot of BS34 fans around this place but I'm not one of them .
Good carbs ain't cheap and cheap carbs generally aren't good.....
Save some money and get a rack of Kehin CRS29 with the following jetting. Just what is the comparison between the 2 like in hp?
120 Main Jets [also get some 115's]
55 Slow Jets
35 Starter Jets
YY7 Needles
Larry C
- Ktm181
19 Nov 2009 15:51
THANKS for all your replies Guys, I have been in touch with Larry C and organized a cylinder head, just waiting on final pricing etc, he seems like a good guy with a good reputation.
Cheers,
Kt
Cheers,
Kt
