horsepower with 1075 & 118 web cam
  • Ktm181
  • Topic Author
  • Man made it, so Man can fix it
16 Nov 2009 15:07 #334137 by Ktm181
horsepower with 1075 & 118 web cam was created by Ktm181
Hello all, been a member for a while but not a big poster, love your attitude to all things Z, mine is like a time machine, it transports me back to simpler times i reckon!
My question for you is related to my Kz900, i am fitting a 1075 kit and 118 web cam but will have to stick with 26 carbs until more money available, what sort of horsepower can i expect without porting and what sort of carbs do you reckomend? I want power 3500 to 8000max rpm.
regards,
Kt.
Emu Plains, Australia.
  • 9am53
  • homebrew, and some bbq
16 Nov 2009 15:10 #334139 by 9am53
Replied by 9am53 on topic horsepower with 1075 & 118 web cam
goodness, not that I know anything, or that it's my place to say, but I think your bike deserves to stay a virgin! I mean look at it!
16 Nov 2009 15:15 #334142 by Old Man Rock
Replied by Old Man Rock on topic horsepower with 1075 & 118 web cam
Stock exhaust, stock gearing & tires, no head work, 26mm carbs with your build..... Somewhere in the mid 90's be a safe guess...
Guys, thoughts?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
16 Nov 2009 15:17 #334144 by roy-b-boy-b
Replied by roy-b-boy-b on topic horsepower with 1075 & 118 web cam
I'm not going to quess on HP figures. if you can get your hands on a set of 29 Mikunis that would be great.
I have used VM28 carbs on my 1075 with Andrews 3x cams and they worked good. I now run BS 34's.
Nice bike. Roy
16 Nov 2009 15:30 - 16 Nov 2009 15:32 #334146 by otakar
Replied by otakar on topic horsepower with 1075 & 118 web cam
Nice bike. Roy
This is a very good combination. If you port the heads and install a good set of BS34s you will get very good power. the 118 cams are a very good cam for the street. The BS34s will allow you to burn the available fuel much more efficiently. A well set up set of BS34s are as good if not better as a set of 31mm Smooth Bores. If you port the head you should be able to get about 95+ Hp with the BS34s. You can get a set of those on eBay for around a $100. Make sure you get a set from a KZ1000 or KZ1100. They have much better needles in them. If you get a set from a 750, they will be too lean unless you spend another $60 for needles. The porting and the carburetors will do more than the cams. Due to the fact that the intake ports will not be sufficient to supply the air that your cams can deliver into the chamber.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 16 Nov 2009 15:32 by otakar.
  • Ktm181
  • Topic Author
16 Nov 2009 16:06 #334162 by Ktm181
Replied by Ktm181 on topic horsepower with 1075 & 118 web cam
THANKYOU so much for your replies guys, i really appreciate it. I am on a budget, arent we all, i may have to stick to colleting the parts and save some more $$$, i would really like the porting as well so will just have to wait i guess. I would like to send the port work to Larry Cavanagh but am a bit nervous sending a head all the way from Australia, might look into it though or Larry may know someone he would recommend down here, I understand he sells equipment to Australian businesses.
I apologize on the "bodgy" photo, i could not for some reason upload the picture of my bike and i wanted a pic of a similar one so grabbed one from somewhere, will have to try again.
Kt.
16 Nov 2009 16:24 #334166 by timebomb33
Replied by timebomb33 on topic horsepower with 1075 & 118 web cam
my 74 with 110 web cams 29 smooth bores a yosh pipe dyna s ignition 1075 wiseco kit and a self ported head made 114 horse and 79 ft.lbs of tourque the one and only time i dyno'ed it. it is a very good combo that i would recommend highly to anyone it can be as wild as you want it to be or as mild as a mouse very street freindly bike. i also went 10.74 at 123 mph with this combo in the same bike
I THINK MY POWERBAND BROKE
  • Ktm181
  • Topic Author
16 Nov 2009 16:29 #334167 by Ktm181
Thanks Timebomb, thats SENSATIONAL.
Hope you like my new Avatar, will try for some better pics!
This is very good therapy, i feel inspired already by you lot !
Kt
16 Nov 2009 16:36 - 16 Nov 2009 16:39 #334169 by otakar
I had roughly the same #s on my 78 Z1R with Yoshi Bonneville cams, Yoshi series 2 pipe RC Engineering 1105 kit and stock 28s. 10.82 @ 132mph
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 16 Nov 2009 16:39 by otakar.
16 Nov 2009 17:06 #334173 by timebomb33
i just tore it down to freshen up the head after 20,000 hard street miles and other than some minor damage to 1 and 2 pistons i'll be putting this motor right back together once i get some rings it will get another 20,000 miles i'm sure. it is getting a fresh paint job as well the engine that is the body is still good.
  • larrycavan
  • Visitor
16 Nov 2009 17:31 #334183 by larrycavan
Replied by larrycavan on topic horsepower with 1075 & 118 web cam
Here's my selection for your bike. It's about strong power in the RPM range you ride most with plenty left over to scare yourself with if you want to.
If you're going to have the head off and apart, skip the 118 grind and get the 483 grind instead. You'll have to clearance the tappet bores a little and remove the X's from the valve cover. Get springs too.
A lot of BS34 fans around this place but I'm not one of them .
Good carbs ain't cheap and cheap carbs generally aren't good.....
Save some money and get a rack of Kehin CRS29 with the following jetting.
120 Main Jets [also get some 115's]
55 Slow Jets
35 Starter Jets
YY7 Needles
Larry C
16 Nov 2009 17:40 #334186 by arai59
Replied by arai59 on topic horsepower with 1075 & 118 web cam
Guys, thoughts?
Dave I think your probably close to reality here. I was thinking around mid eigties at best.
