Valve Cover removal question
12 Nov 2009 02:38 #333058 by sakiguy
Valve Cover removal question was created by sakiguy
I want to retorque the cylinder head bolts, and to do that I have to remove the valve covers to get clearance. I was wondering if I would have to replace the valve cover gaskets if I removed them or if I could just reuse them.
1983 KZ750 N2 Shaft
12 Nov 2009 02:52 #333059 by loudhvx
Replied by loudhvx on topic Valve Cover removal question
That depends on how the old gasket was put on. I polish the cover and head surface, then use anti-seize on the gasket. I can reuse the gasket 4 or 5 times that way. It comes off like brand new.
I don't know what motor we are talking about, but if it's a motor with hyvo cam chain (with chain guide in the valve cover), remember to release the timing-chain tensioner before putting the valve cover back on. If you don't, you can break the chain, or tensioner, or guides. :(
12 Nov 2009 03:20 #333064 by sakiguy
Replied by sakiguy on topic Valve Cover removal question
My bike is a 1983 kz750n2 shaft. Not sure if it has a chain guide in the valve cover. I got the manual though so I'll check.
1983 KZ750 N2 Shaft
12 Nov 2009 06:28 #333082 by RonKZ650
Replied by RonKZ650 on topic Valve Cover removal question
No need to remove anything to torque the head, all 12 14mm head bolts can all be easily accessed.
  • txturbo
  • Ex-Kawasaki Mechanic 1981-1985
12 Nov 2009 07:14 #333093 by txturbo
Replied by txturbo on topic Valve Cover removal question
Valve cover doesn't need to be removed, but you will need to remove the tank and possibly the coils.
1984 ZX750 E1 GPz Turbo
1984 ZX1100 A2 GPz
1984 ZX900
1996 KZ1000P Police bike
1970 Honda CT 70H 4sp manual
1965 Honda Dream 305
2003 Honda Shadow 1100
1971 Suzuki MT50 Trailhopper
1969 Camaro SS
1966 Impala
1966 Impala SS 427/4spd
12 Nov 2009 10:48 - 12 Nov 2009 10:48 #333129 by sakiguy
I was looking at it last night and it looked like the valve covers blocked some of the head bolts...but after looking at it in some light, you guys are right, they made holes so that you can access them. Tanks is actually off already. Man that just saved me a lot of time. :)
1983 KZ750 N2 Shaft
Last edit: 12 Nov 2009 10:48 by sakiguy.
12 Nov 2009 10:56 #333132 by MFolks
Replied by MFolks on topic Valve Cover removal question
I've read/heard that spraying new valve cover gaskets with non stick cooking spray(like PAM) will do the same thing.
14 Nov 2009 10:21 #333619 by sakiguy
Should I loosen all the head bolts first before retorquing them to possibly avoid overtightening?
1983 KZ750 N2 Shaft
14 Nov 2009 10:45 #333622 by RonKZ650
Yes, just barely loosen them, then torque to spec.
