Weird smoke coming out.
11 Nov 2009 17:52 #332944 by cperrotta
Weird smoke coming out. was created by cperrotta
Ok, so when i start up my bike it's alright. within about 5 or 6 minutes of idling there is smoke coming out from my exhaust, not blue but a dark smoke indeed. there is a small crack in the muffler clamp underneath where the two sides are connected by that pipe, but that's a side-note to add to the problem. i was told it could be running rich, but i'm wondering why it would be smoking after 5 or 6 minutes? i'm thinking a possible gasket or seal somewhere is old and needs replacing. any ideas?
thanks.
12 Nov 2009 10:42 #333126 by bountyhunter
Replied by bountyhunter on topic Weird smoke coming out.
What kind of bike is it?
12 Nov 2009 14:35 #333157 by cperrotta
Replied by cperrotta on topic Weird smoke coming out.
my apologies for not posting that. it's a 1981 kz 750
12 Nov 2009 14:43 #333158 by YUKABODOS
Replied by YUKABODOS on topic Weird smoke coming out.
Could it be burning oil? Have you monitired the oil level in the oil window?
12 Nov 2009 14:47 #333159 by cperrotta
i recently changed the oil and filter, and noticed the oil level was pretty consistent before that as well. it doesn't smell, look or feel like it's oil being burnt.
  • larrycavan
  • Visitor
12 Nov 2009 14:53 #333160 by larrycavan
Replied by larrycavan on topic Weird smoke coming out.
What can happen on those bikes is if the oil level had been over filled at some point, excess oil can get forced into the airbox and saturate the air filter. It would make it run rich as a result.
12 Nov 2009 15:01 #333162 by cperrotta
i blew out the air filter the same day i changed the oil, it was clean as a whistle. the gasket underneath the filter though was soaked in gas.
12 Nov 2009 17:25 #333209 by Patton
Replied by Patton on topic Weird smoke coming out.
:unsure: Does this mean that there's fuel collecting in bottom of airbox? :unsure:
Good Luck! :)
12 Nov 2009 17:42 #333227 by cperrotta
looks to be the case. the fuel hoses are ok though.
12 Nov 2009 17:51 #333235 by kawsakiman
Replied by kawsakiman on topic Weird smoke coming out.
when is the last time you changed the air filter?
believe it or not i have seen a dirty air filter cause what i call too much vacuum and pull fuel out of the bowls.
(sucks too hard? :blink: )
12 Nov 2009 17:56 #333240 by cperrotta
as far as i know it's the same air filter. now could there to be much vacuum with the filter cap not secured down properly, or am i thinking in reverse here? seems like it would try to suck more air w/o a proper seal.
12 Nov 2009 18:09 - 14 Nov 2009 05:20 #333248 by Patton
The danger is possibility of leaking float valves allowing excess fuel to rise into the carb throat and migrate into the crankcase whereby the oil becomes contaminated with raw fuel.
Would sniff-test oil and examine its physical condition.
If oil is fuel-contaminated, would change oil and filter, and not again run the engine until the issue is resolved.
Good Luck! :)
Last edit: 14 Nov 2009 05:20 by Patton.
