Capping off the Clean-Air Intake Vacuum Thingy
11 Nov 2009 09:32 #332855 by chrispysaki
It was mentioned in another thread that some people cap off the clean-air vacuum intakes that go to the exhaust side of the valve cover. Does this make any difference in performance, engine life, or anything else that might matter — other than the amount of emissions coming from my tailpipe?
11 Nov 2009 09:39 #332856 by BSKZ650
Most of the time they are not working to start with so I would think maybe a little better performance would be seen , but in any event a good tune up would help also
77 ltd1000, current rider
76 kz900, just waiting
  • TeK9iNe
  • What did you do!?!
11 Nov 2009 10:01 - 11 Nov 2009 10:02 #332858 by TeK9iNe
Something to remember: If you remove the "clean air" system, chrome pipes (especially new ones) will blue very easily and rapidly at thier first bend from higher exhaust temp.
To prevent this!: Spray a few cotes of VHT high heat header paint down inside the pipes, and it will reduce the blueing effect dramatically. ;)
Good luck,
Cheers.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 11 Nov 2009 10:02 by TeK9iNe.
11 Nov 2009 18:06 #332953 by thompsonmx100
Replied by thompsonmx100 on topic Capping off the Clean-Air Intake Vacuum Thingy
I posted in your other thread before I saw this one I have a scource that makes block off plates for the 750 the ones APE makes wont fit. PM me if you want this info.
2006 gs 500 streetfighter
1982 gpz750 breathed on wreck
1985 gpz750
Kz 650
11 Nov 2009 18:27 #332964 by tomsweb1
Replied by tomsweb1 on topic Capping off the Clean-Air Intake Vacuum Thingy
Canadian models don't have these... just thought I'd brag.
:P
1978 CB400A Hondamatic
1983 CB550SC Nighthawk
1978 CB750A Hondamatic
1982 KZ1300
11 Nov 2009 22:31 #333048 by chrispysaki
Replied by chrispysaki on topic Capping off the Clean-Air Intake Vacuum Thingy
Thanks for the offer, Travis. How much do they go for? By the way, I'm loving your build. Definitely some impressive work there.
12 Nov 2009 05:52 #333075 by Bluemeanie
Replied by Bluemeanie on topic Capping off the Clean-Air Intake Vacuum Thingy
The bike will run pretty much the same except you may notice less popping when letting off the throttle as the unburned fuel is not being ignited by the introduction of fresh air. Of course it also cleans up the motor area. Mine have been deactivated for over 20 years. :)
12 Nov 2009 15:49 - 12 Nov 2009 15:50 #333169 by thompsonmx100
Thanks for the comment on my build. The block off plates were affordable they were in the 40 dollar range shipped. they are cool he has kz one also. I sent him one of mine and he put it in his data bank. I'm kinda surprised he doesn't list them on ebay. heres a pic of mine
actually these aren't mine these are the ones he makes for the 1000 mine are the same except they fit the 750
1985 gpz750
Kz 650
Last edit: 12 Nov 2009 15:50 by thompsonmx100.
