kz 1000, 1100 questions
  • mach1charlie
  • Topic Author
10 Nov 2009 09:54 #332628 by mach1charlie
kz 1000, 1100 questions was created by mach1charlie
I ride an 1996 kz 1000 police bike, its my daily rider has 75,000 miles on her and she smokes some on deaceleration.
So, I am thinking about pistons and rings, a little porting head clean up, maybe slip in some gpz cams from ebay.
Will 1100 jugs fit into my 1000 cases with out machine work?
How far (mm) can I bore 1100 jugs?
Or can I bore my 1000 jugs to std. 1100 size ?
Thanks
Charlie
10 Nov 2009 11:35 #332645 by PLUMMEN
Replied by PLUMMEN on topic kz 1000, 1100 questions
id say 1075 on the 1000 block,1170 on the 1100.youll have to clearance your cases for the 1100 sleeves i think.but as always check with craigy/greggy at arai/69/lovetrianglelaguna just to be sure,ive been wrong a lot lately! B)
10 Nov 2009 16:29 #332685 by hoghaterkaw
Replied by hoghaterkaw on topic kz 1000, 1100 questions
please correct me if i'm wrong. at some point during the 1980's the police bike motor changed over to the "j" motor and ran until Kawasaki stopped production. the elr was a 1000cc "j" motor in 1982. will a "j" 1100cc block fit in a cop motor case, i can't say for sure. others??
10 Nov 2009 16:33 #332687 by PLUMMEN
the cop bikes kept the 1000j motor from 81 untill around 98 im pretty sure,again the brothers dim will be along to correct me im sure! B)
10 Nov 2009 18:45 #332718 by kpier998
Replied by kpier998 on topic kz 1000, 1100 questions
Yes it is a J motor. That just means that you need to buy pistons for a J motor not the older KZ. The 1075 kit is a good size for the 1000 (998 std). If you can come up with a set of 1089 (J motor 1100) cylinders they can be bored more.
Check out the KZZONE at APE for more information.
10 Nov 2009 19:18 #332732 by otakar
Replied by otakar on topic kz 1000, 1100 questions
I did exactly just the same thing on my 1000CSR motor. The 1100 jugs drop right in. I highly recommend against the 1170 pistons because the wall thickness will be less than 1mm. I went to 1150 with custom pistons but the 1135 is the perfect choice and totally reliable. You will be able to run the bike without an oil cooler with no problem.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
10 Nov 2009 20:21 #332745 by APE Jay
Replied by APE Jay on topic kz 1000, 1100 questions
You are incorrect about the 1170 kit being less than .040" wall thickness in an 1100 block.
Jay
11 Nov 2009 05:38 #332787 by otakar
Sorry, I meant to say that you will have less than 1.5mm My outside sleeve diameters at the lower skirts measure 77.78mm the bore would be 75mm with the 1166 kit. No reputable rebuilder would recommend less than .060" for reliable street use. This is one of the reasons that MTC has not offered this option. It is not worth the risk. This is exactly the same reason why the 1075 kit is much more popular than the 1103 kit, on the 1000cc blocks. Issue is reliability.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • TeK9iNe
  • What did you do!?!
11 Nov 2009 10:19 #332860 by TeK9iNe
Replied by TeK9iNe on topic kz 1000, 1100 questions
Aggghhhhh.... Drool.
:lol: :laugh: :woohoo:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
