cam cap bolts...
  • Randall the Vandal
  • Topic Author
09 Nov 2009 18:10 #332475 by Randall the Vandal
cam cap bolts... was created by Randall the Vandal
have some stripped cam cap bolts and tapped them out to M8. the bolts are shouldered and are tight in the cap. since i cant use the knock pins but there is 0 play between the bold and cap. opinions if this will suffice on cap alignment.
1976 kz900 ltd
1981 csr1000
1982 kz1100
2007 klr650
  • TeK9iNe
  • What did you do!?!
10 Nov 2009 04:17 #332575 by TeK9iNe
Replied by TeK9iNe on topic cam cap bolts...
If there truly is o.ooo inches play, personally, I would use all new cam bushings and break-in lube.
New, new, new... makes it all work wonderful :laugh:
Good luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • Topic Author
14 Nov 2009 15:56 #333679 by Randall the Vandal
Replied by Randall the Vandal on topic cam cap bolts...
thanks for that...i was expecting a tidal wave of HELL NO's.
1976 kz900 ltd
1981 csr1000
1982 kz1100
2007 klr650
14 Nov 2009 17:32 #333704 by gane
Replied by gane on topic cam cap bolts...
Randal, Unless you've wear in cam bearings, and indeed caps are tight to new bolts, I would simply place strands of plasti-gauge under cams at bearings, torque/remove & measure. any miss-alignment of caps will show as tight areas if diffence is gross. if within spec. run a couple of minutes and re-inspect bearings at caps. Cam bearings are pretty forgiving, I guess thats why there's only 1 size. Heads & towers were line bored at manufacture, thus caps aren't avail. seperate. however, I've seen many cracked caps swappped w/out incident. hope this helps. G
[img][/img] 1977 KZ1000A1
14 Nov 2009 17:46 #333710 by Buda
Replied by Buda on topic cam cap bolts...
I did the same thing this past spring and ran all summer with no problems.
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
  • Topic Author
18 Nov 2009 16:23 #334517 by Randall the Vandal
Thanks for the info guys...this is my first "top end" job and i want to be confident in the work i'm doing.
1976 kz900 ltd
1981 csr1000
1982 kz1100
2007 klr650
