Permatex Grey - gasket maker
  • JR
  • Topic Author
09 Nov 2009 14:12 #332412 by JR
Permatex Grey - gasket maker was created by JR
This is probably a dumb question. I have this tube of Permatex Grey gasket maker and was wondering if I can us it to mate the valve cover to the cylinder head - ie instead of a gasket...........or should I just go ahead and buy the valve cover gasket ?
09 Nov 2009 14:16 #332413 by PLUMMEN
Replied by PLUMMEN on topic Permatex Grey - gasket maker
buy a gasket and a can of spray on copper coat to glue it to valve cover .but as the legal dept keeps reminding me you should clear all posts/techno stuff through trianglelaguna and arai59 aka greg and craig enterprises to be safe B)
09 Nov 2009 14:24 #332416 by Locozuna
Replied by Locozuna on topic Permatex Grey - gasket maker
Yes!!! Buy a gasket and the copper spray. You will thank yourself. Just had to re-do an oil pan. Second time I used the copper and it is nice! No worries! ;)
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
09 Nov 2009 15:45 #332430 by RonKZ650
Replied by RonKZ650 on topic Permatex Grey - gasket maker
Probably been mentioned numerous times before, but use a gasket for sure. Whatever you do don't seal both sides. It makes for a huge mess next time. Do it dry, use a decent gasket and if surfaces are clean it won't leak, otherwise use the seal on the engine side only, leave the valve cover side dry and the cover comes right off from then on out and can be reused.
09 Nov 2009 16:57 - 09 Nov 2009 17:07 #332444 by Old Man Rock
Replied by Old Man Rock on topic Permatex Grey - gasket maker
Valve cover gaskets are cheap $10 at Z1....
Basically the price of a Happy meal any longer.....
EIDT:
As mentioned, pay the extra $10 bucks for the permatex compounds thus no leaky....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 09 Nov 2009 17:07 by Old Man Rock.
  • JR
  • Topic Author
09 Nov 2009 18:51 #332493 by JR
Replied by JR on topic Permatex Grey - gasket maker
Thanks gentlemen. Ma Kaw gasket ordered from the local dealer. It will probably cost me and arm and a leg but at least it will be here on Wednesday. Not many riding days left up here and if the weather holds I just might make it to Port Dover on Friday the 13th
  • hugo
  • '92 Zephyr 750
10 Nov 2009 04:16 - 10 Nov 2009 04:19 #332574 by hugo
Replied by hugo on topic Permatex Grey - gasket maker
Don't feel too bad for the price, I have a Zephyr 750 and the gasket is about $40.00. The less expensive KZ750/650 won't fit properly because the Zephyr valve cover mimicks the Z900.
The Zeph gasket is impregnated with graphite, which is an excellent sealer. Manual says apply it dry. The problem is when you want to remove it, leaves residues on the surfaces very hard to scrape. You don't need to help the sealing, but need something to make it easier to remove. Even non-stick cooking oil would help. I usualy lube it with moly grease.
Last edit: 10 Nov 2009 04:19 by hugo.
