hopefully this will be the end of problems...
  • cricketfire46
  • Topic Author
04 Nov 2009 17:20 #331565 by cricketfire46
hopefully this will be the end of problems... was created by cricketfire46
finally got my 83 kz750 LTD all taken apart and parts to fix it, just one last question... Got starter clutch out, had to drop oil pan though. The rollers are in great shape, the pins still look really good. The springs are shot though. Are these springs going to be a shop part, or can I run down to a lawnmower and small engine shop? local dealer wants like 30$ for a set of 3. I dont think a spring that small is worth that much... ideas? suggestions??
83 kz750 ltd, dyna coils, k&n, mac 4->1 just rolled 50k
04 Nov 2009 17:23 #331567 by otakar
If the springs you find are the same size and same rate they will be fine, if not than you will have problems.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
04 Nov 2009 17:27 #331568 by keith1
peruse the redline cycle site...they have them and have a good write up about how to service starter clutches...
  • cricketfire46
  • Topic Author
04 Nov 2009 17:33 #331569 by cricketfire46
Replied by cricketfire46 on topic hopefully this will be the end of problems...
any idea what the rate is? shop manual is at home and i am working
  • hugo
  • '92 Zephyr 750
06 Nov 2009 07:24 - 06 Nov 2009 07:27 #331738 by hugo
Your are right that $30 dollars seems too much for some small springs, but they have factored in the price all these;
-It will be difficult for you to figure out the rate and material.
-The labor involved if you guess wrong, would much more than $30, doing it again, even if you do it yourself. How much is your time worth?
-The US Dollar is worth less and less because we don't make anything anymore.
I would buy stock from on line distributors like Ron Ayers that usually sell for little less than dealers.
Last edit: 06 Nov 2009 07:27 by hugo.
06 Nov 2009 07:28 #331740 by timebomb33
Replied by timebomb33 on topic hopefully this will be the end of problems...
while you have it all apart check the sprag itself look for indentations or flat spotting that is normally the cause of failure in the first place with starter clutches it doesn't take much. so just a heads up before you put it all back together. the pins will flat spot but so wont the sprag.
I THINK MY POWERBAND BROKE
