Those Rubber Vibration dampers Actually Work
  • bountyhunter
  • Topic Author
04 Nov 2009 13:36 #331540 by bountyhunter
Those Rubber Vibration dampers Actually Work was created by bountyhunter
I recently ordered a new set of those little rubber plugs that go between the vertical fins at the top of the head above the spark plugs. I only had a couple left in my 750 twin. I popped out the last two and they were as hard as rocks.
I put four on each side because there are four gaps, even though the drawing only calls out three per side.
They actually do something. I had annoying harmonic vibration in the 3500 - 4000 range in high gear which seems to be gone. It now feels pretty much like when it was new. I assumed the gradual increase in vibration was wear in the engine or balancer, but maybe not. I guess those dampers just hardened over time and a couple fell out which made the felt vibration increase. So, good to know they are there for a reason.
04 Nov 2009 13:50 #331541 by otakar
Post a picture. Good heads-up.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • bountyhunter
  • Topic Author
04 Nov 2009 16:43 #331561 by bountyhunter
Replied by bountyhunter on topic Those Rubber Vibration dampers Actually Work
Here's a picture
05 Nov 2009 05:24 #331628 by Bluemeanie
Replied by Bluemeanie on topic Those Rubber Vibration dampers Actually Work
Interesting. So if I put 10-20 in the fins of my 650 maybe my mirrors would be usefull at freeway speeds? :woohoo:
  • bountyhunter
  • Topic Author
05 Nov 2009 10:58 #331659 by bountyhunter
I thought the fours were supposed to be smoother than the twins....?
05 Nov 2009 18:20 #331696 by Bluemeanie
Yea, they are but mirrors are useless at 6000rpm on the freeway! ;)
  • TeK9iNe
  • What did you do!?!
06 Nov 2009 08:08 #331755 by TeK9iNe
Replied by TeK9iNe on topic Those Rubber Vibration dampers Actually Work
If there's nothing on the inside of your handle bars, you can fill them completely with caulking or any other rubberized sealer.
It literally KILLS the vibration and mirrors become usable anywhere/anytime.
Cheers!
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
