Please HELP....Clutch cover installation issues.
  • 550A2
  • Topic Author
  • keep the shiny side up
03 Nov 2009 09:38 #331286 by 550A2
Well i had to take the clutch cover off to get to a motor mount bolt so i could shift the engine and fix a broken exhaust stud that was right behind the frame. ugh! what a b*tch.
It came off fairly easily without any problems. But now im trying to put it back on and it fits on fine it seems but when i pull the clutch lever (it has no tension whatsoever)
I made sure the clutch push rod was seated in the forwarding mechanism and it is still doing it, like its not pushing the push rod at all.
Im working on getting it fixed now, but i need it on by 1 so i can get to school.
Some help would be VERY MUCH APPRETIATED!
Thanks in advance!
Luke
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
  • 550A2
  • Topic Author
03 Nov 2009 10:06 #331294 by 550A2
its an 82 kz550 a2 by the way
03 Nov 2009 12:15 #331309 by Link14
Is there a chance that the ball bearing between the clutch push rod and the clutch spring plate pusher feel out? If that was missing, I'm guessing you wouldn't feel any tension when you pulled the clutch lever.
03 Nov 2009 14:21 #331325 by 82kz1000P
Replied by 82kz1000P on topic Please HELP....Clutch cover installation issues.
With the cover off, looking at the underside of the cover, you should see the mechanism push out as you squeeze the clutch lever; it pushes against the rod which provides the clutch lever return force. My guess is you left a piece out; look around the ground.
