? Heli coil?
- spearsgaryhi
? Heli coil?
03 Nov 2009 07:34
Can anyone tell me what heli coil product to perchas to fix a bolt holding a camshaft cap on 76'kz900 ltd? Not the bolt it self. But the femail end of the situation. A part # would be great. Thanks guys.
Re: ? Heli coil?
03 Nov 2009 09:42 - 03 Nov 2009 09:42
it should be a 6mm 1.25 pitch i think.i got mine from o'riellys for like $40.00 for the kit.take a bolt to the store with you to make sure you get the right one.hth,
leon holmes
leon holmes
Last edit: 03 Nov 2009 09:42 by 531blackbanshee.
Re: ? Heli coil?
03 Nov 2009 09:44
You should look into timeserts (do a search on this site). Folks here say they are superior to helicoils. Ed
- Mcdroid
- Gone Kwackers
Re: ? Heli coil?
03 Nov 2009 10:08 - 03 Nov 2009 10:08
650ed wrote:
I am replacing many of my camcap bolt threads on my 1100 (which were heli-coiled by the PO) with time serts (Big serts). They (helicoils) have a tendency to pull out...eventually.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 03 Nov 2009 10:08 by Mcdroid. Reason: clarity
Re: ? Heli coil?
03 Nov 2009 12:10
my theory(however flawed
)has been to use heli-coils first then when they pull out,go to timeserts,when they fail,stepped studs when they fail,weld it up and re-machine.i could be overthinking things here tho perhaps.:woohoo: you would prolly never have to mess with timeserts again tho,if you went that way.helicoils if installed right and used carefully can last a while.i have 21 helicoiled holes in the head on my 1980 z1r,so far so good.i do figure to have to address them at some point tho.here is a link to timeserts,looks like i was wrong about the thread pitch should be 1. not 1.125.
www.wttool.com/category-exec/category_id/14508
hth,
leon holmes
hth,
leon holmes
- BSKZ650
Re: ? Heli coil?
03 Nov 2009 12:19
heli coils will last damn near forever, IF you will put some type of lube on the bolt when you install it, the coils are made from SS and can "seize" on the bolt.
Thats the main reason the fail, or pull out at some point.
The same can be said for any bolt that goes into alum or SS.
77 ltd1000, current rider
76 kz900, just waiting
- spearsgaryhi
Re: ? Heli coil?
03 Nov 2009 18:57 - 03 Nov 2009 19:18
Great feedback guys. You all rule! I just orderd a timeserts kit. Aloha:lol:
Last edit: 03 Nov 2009 19:18 by spearsgaryhi.
