- Thank you received: 1
clutch handle not releasing
- kz1100warrior
27 Oct 2009 03:24 #329890
by kz1100warrior
clutch handle not releasing was created by kz1100warrior
okay, i read most posts here regarding slipped clutches etc, my problem i hav is that my clutch handle will not release once i have put in gear.....could this be the spring by end of cable worn or would this be a push rod scenerio. Once i engage in a gear i have to push the clutch out it will not go back automatically....
any help chaps
any help chaps
- Locozuna
27 Oct 2009 05:27 #329900
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic clutch handle not releasing
First I'd remove the cable to make sure it's not gummed up. Then I'd look at the cable end cam. If those prove to be freely moving make sure your clutch rod is moving free. After that you go over to the clutch basket itself. I bet you find it before this. All pretty simple really. What model is it. Do you have a manual?
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- Old Man Rock
- Thank you received: 225
27 Oct 2009 05:31 #329902
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic clutch handle not releasing
Assuming KZ1100 due to nick....
Start with adjustments... Here's the procedure for a KZ900, maybe similar to yours...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
