- Thank you received: 1
Engine tach cable connection leaks.
- polkat
27 Oct 2009 01:29 #329883
by polkat
Engine tach cable connection leaks. was created by polkat
Where the tach cable enters the front of my 750-4 engine, it is leaking. Before I take it apart, what is in there? A gasket, rubber O ring, or...? kawa parts are hard to get here, so could this be a silicon fix? Thanks!
- Thank you received: 2098
27 Oct 2009 02:22 #329884
by Patton
Replied by Patton on topic Engine tach cable connection leaks.
Likely needs a tach oil seal.
Click here > Z1E tach oil seal
Would also replace the o-ring between tach drive and head.
Not supposed to leak, even with tach cable disconnected from the drive.
Some folks take pains to seal the knurled screw connection where tach cable attaches to the drive. Which doesn't remedy leakage around the tach drive shaft, but may contain the leakage within the cable sheath.
Good Luck!
Good Luck!
- JR
- Thank you received: 448
27 Oct 2009 16:23 #329973
by JR
Replied by JR on topic Engine tach cable connection leaks.
I got a pack of assorted plumbing washers at a local hardware store and one of them fit and worked - that was 7 years ago.
The one from Z1E for which Patton supplied the link looks like the best bet.
