Spark plug HELI COIL?
- KZ1100 Bully
24 Oct 2009 18:40
I need to Heli coil my # 4 sprk plug hole while the head is off.
Not sure what to buy, do I drill it or tap it? What size do I buy? The hole is very stripped.
Thanks
Thanks
1983 Kawasaki KZ1100 Spectre D2
- timebomb33
Re: Spark plug HELI COIL?
24 Oct 2009 18:54
there is aproduct available at most napa stores called save a thread it is a solid steel insert and install tool that i have used many times in the past a heli coil can actually blow out so i recommend using these solid steel inserts they are very easy to install the directions are self explanitory and i've have never had one pull out. in fact i have a set with me in my track box and a set at home a very good product.
I THINK MY POWERBAND BROKE
- gearhead119
24 Oct 2009 19:10
Most older KZ's had 14mm x 1.25 threads. These are the sparkplugs starting with a "B"... B7ES , BR8ES , BPR7ES...... If the sparkplug starts with a letter "D" they are 12mm x 1.25.... DPR7EA-9, D7EA, .... Depends on what is supposed to be in there...
Oh those plug #'s are NGK brand
i would stay away from helicoils if I was you... especially on the sparkplugs. They are rarly a successful fix and almost never a permenant fix. They are great for REALLY screwing up a fixable head to the point that they are beyound an Easy fix. "Time-Sert" is another brand of solid inserts that are availible and work really well .. they have a shoulder on the top of them... along with a countersink bit in the kit. leaving a completly flush mount when done correctly. I think there are 2 or 3 different lengths availible. more then likely the long one will work great! Good luck
2000 Zrx1100 Turbo-220bhp/145lbs torque
1978 KZ 1000 project-in progress
- timebomb33
24 Oct 2009 19:21
time serts are very hard to get in canada wurth is the only company that has rights to them up here that is why i recommended save a thread you can get them from any napa dealer and they are identical to the timeserts installed the same way and everything.
- kawsakiman
24 Oct 2009 20:44
i helicoiled #3 on the 1100 two years ago with no ill effects.
of course i have not changed the plugs since then :whistle:.............................
- KZ1100 Bully
25 Oct 2009 04:37
Right on thanks guys. I have NGK BBES plugs so I will buy 14mm x 1.25 threads. I will buy Save a thread from Napa, here in Canada.
You guys are great. You make fixing a bike so much easier.
Thanks
Thanks
- Old Man Rock
25 Oct 2009 05:31
Stevie! "of course i have not changed the plugs since then "... :ohmy: :huh: :dry:
NGK plugs are what, $2.50 each, you cheap S.O.B.! :S
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kawsakiman
25 Oct 2009 15:17
if you know how to sync your carbs you don't need to change plugs so often
