cam cap dowels?
- KZ1100 Bully
24 Oct 2009 14:05 - 24 Oct 2009 14:06 #329367
by KZ1100 Bully
1983 Kawasaki KZ1100 Spectre D2
cam cap dowels? was created by KZ1100 Bully
HI, I read a few of the other post here but did not find my answer.
How may cam cap dowels are there. It seems I am missing a 6 dowels. There was 2 on most chris crossed and some had some had 3.
Question is do I need 4 dowels in each cap? If so I'm missing 6.
Last edit: 24 Oct 2009 14:06 by KZ1100 Bully.
- KZ1100 Bully
24 Oct 2009 14:16 #329368
by KZ1100 Bully
Replied by KZ1100 Bully on topic cam cap dowels?
I found the answer to my question they are chris crossed 2 dowels per cap.
I have 2 bigger dowels that I don't know were they go. They don't fit in the caps to big. I can remember one was on each side but not were.
Getting ready to put top end back together.
- timebomb33
- Thank you received: 10
24 Oct 2009 14:51 - 24 Oct 2009 14:52 #329369
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic cam cap dowels?
do you have the cylinder head and block right off the engine if you do there are two places the big dowels can be coming from at the end of the block there is a dowel hole centered on the end that one is used to locate the cylinder head and then there are two more that locate the block to the cases. and one more thing they are very important to have in the motor they center every thing.
Last edit: 24 Oct 2009 14:52 by timebomb33.
- KZ1100 Bully
24 Oct 2009 15:33 #329380
by KZ1100 Bully
Thanks timebomb33, the only place they fit is on the ends of block at the center. I do have cylinder head and block right off the engine. I wanted to change the rear cam guide it was the one wore bad, the front guide was good but rock hard.
Changed it as well.
Thanks
Changed it as well.
Thanks
