- Thank you received: 3
Piston Gas Porting
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
24 Oct 2009 13:15 #329365
by kzz1p
Replied by kzz1p on topic Piston Gas Porting
- APE Jay
- Banned
- Thank you received: 58
24 Oct 2009 21:54 #329447
by APE Jay
Replied by APE Jay on topic Piston Gas Porting
kzz1p wrote:
We usually only do dragbikes and have not seen any drastic wear.
It is interesting that the new German Wossner turbo pistons are coming from the factory with gas porting.
Interesting tid bit. Radial gas porting, which is harder to do, was originally done as a "cheating" method in stock cars where gas porting was not legal. With radial gas porting, you can not tell if the piston is in the cylinder.
APE Jay wrote:
We usually do 8
Jay
Does the wear rate of the rings increase?
- kzz1p
24 Oct 2009 22:14 #329449
by kzz1p
APE Jay wrote:
Jay
Thanks for your answer!
kzz1p wrote:
APE Jay wrote:
We usually do 8
Jay
Jay
- ArthurGoVroom
- I'd rather ride it than shine it
25 Oct 2009 10:42 #329506
by ArthurGoVroom
1976 KZ900A4, 4-1 header, rear lowering kit, grab bar removed, still shining and painting parts as time permits
Replied by ArthurGoVroom on topic Piston Gas Porting
kzz1p wrote:
Yes. The gain was more pronounced at and above the peak HP point. I attribute at least some of this to the lower mass piston though. I agree with the general consensus here that gasporting helps more in the higher compression/boost applications.
As for clogging up the gasports...If you run them on alcohol you don't have that problem
Was your 10% gain, in the upper RPM range?
- PLUMMEN
- Thank you received: 104
25 Oct 2009 11:03 #329514
by PLUMMEN
Replied by PLUMMEN on topic Piston Gas Porting
APE Jay wrote:
cheating in racing? :laugh: say it isnt so,thats why i tend to follow the old saying of run what ya brung and hope its enough! :woohoo:kzz1p wrote:
APE Jay wrote:
We usually do 8
Jay
