tdc?
- KZ1100 Bully
21 Oct 2009 15:24 #328783
by KZ1100 Bully
1983 Kawasaki KZ1100 Spectre D2
tdc? was created by KZ1100 Bully
Hi, getting ready to put the top end back together. When I took it apart tdc was located on the f mark, that is were the 44th links were with the cam chain and the #1 cinder was at the top.
? is should it not be on the T mark not the F mark?
I set the dyna s before with the T make and it seems to run fine.
Not sure why it is running ok if it is tdc with the f mark.
- timebomb33
- Thank you received: 10
21 Oct 2009 19:29 #328816
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic tdc?
the t mark is topdead center the f mark if full advance mark
- KZ1100 Bully
21 Oct 2009 19:59 #328820
by KZ1100 Bully
- KZ1100 Bully
22 Oct 2009 06:04 #328854
by KZ1100 Bully
Replied by KZ1100 Bully on topic tdc?
So with my cam sprockets being tdc with the F mark. I should see an improvement when I set the tdc with the sprockets and the T mark.
The bike is set with the sprockets right but the F mark is wrong. That is the only way I could count 44 links.
Maybe that is why the Auto Cam-chain tensioner was fully extended.
- timebomb33
22 Oct 2009 11:49 #328877
by timebomb33
set your cam timing to the t mark that is where the factory calls for
- TeK9iNe
- What did you do!?!
- Thank you received: 28
22 Oct 2009 14:22 - 22 Oct 2009 14:25 #328920
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic tdc?
The cam chain length is not affected by the timing of the cams/crank. If you have everything bolted up and the cam chain tensioner is reaching full extension, then your cam chain is shot, and you deffinately need a new one.
Manual cam chain tensioner should never be more than finger tight + 1/8th turn. Then check it periodically afterwards till the new chain stretches/settles at its new length.
Good luck!
PS. Oh yeah! , When you set your Dyna S timing, do it by revving the engine and holding it at 4krpms. Then set the mark to the F (full advance). This is how Dyna does it, and trust me it makes a big difference in performance.
Cheers!
Good luck!
Cheers!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 22 Oct 2009 14:25 by TeK9iNe.
- Old Man Rock
- Thank you received: 225
22 Oct 2009 16:40 #328954
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic tdc?
Tek @ "holding it at 4krpms."... :huh:
My KZ900 Dyna-S instructions for Dynamic timing is accomplished at 2500rpms... You sure about that 4k?
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- loudhvx
- Thank you received: 1616
22 Oct 2009 17:21 #328989
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic tdc?
"F" is full advance on the KZ1100 ?
On the 550's "F" is the fire mark which would be at idle. At full advance, there are two parallel lines to indicate the timing mark. "T" is still top dead center, though.
1981 KZ550 D1 gpz.
Other links.
