sluggish, weighed down, low power....
- soccerd31
oil was changed earlier in season, and level was always watched (it DID go through some oil) ran about 1,500-2000 miles this year...
replaced rubber carb boots connecting to the carb to the engine because originals leaked air (which reduced power) all are tight and not currently leaking
i've threw some sea foam in the gas and a lil in the oil AFTER i noticed she was running slow (the thought of carbs maybe getting some build up could reduce power)
i HAVE had electrical problems including one of the main power leads nearly rotting through less than a month after i bought it on saint patricks day 2009... and i wouldn't be surprised if i might have another electrical problem... i plan on gutting most of evrything electrically this winter... could this be a problem reducing power? maybe misfiring?
i DID replace all 4 spark plugs in July....
replace the clutch cable in June
replaced the throttle cable in late september... the throttle cable broke the day after i noticed loss of power... (any correlation?)
things i haven't done (that i THINK i might need to look into):
checked fuel filter
cleaned carbs
sooooo how bout some professional opinions???? what might make my bike DRASTICALLY lose power??? i want to get her back to life!! she's a great bike!
1981 KZ750 LTD H2
- Vter Bob
- Thank you received: 4
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
- chance
- Life long biker/
- tjk
FIDO
- soccerd31
and i'll look into the fuel filter, draining carbs, etc stuff... i drained the carbs when i bought the bike... aaaand... fuel filter LOOKS easy... never messed with it though...
thanks for the suggestions..... anyone else have any recommendations for me???
1981 KZ750 LTD H2
- BSKZ650
- Thank you received: 14
Also look at the choke mechanism, could it be on thus causing it to run rich.
And as stated, do a complete and through tune up including, NEW plugs, check the valves. run a compression check, make sure the timing has not moved ( had that happen once ), check the voltage to the coils and clean up the electrical system.
hope this helps
77 ltd1000, current rider
76 kz900, just waiting
- soccerd31
throtle is good... not sticking... my particular model only has the pull (not a push and a pull).. my throtle seems to have good action.. not loose... not tight... works normal... and i did check both connection ends.. they're both installed correctly....
choke is not an issue... i have to run the choke to start the bike.... and i know its off when i ride....
i planned on doing another set of new plugs a lil closer to the spring riding season...
i KNOW there's electrical problems all over this bike... and i'm wondering if i might not be getting electricity to my plugs for proper firing (as someone mentioned... check for firing)... it seems like i might not be running on all 4.... which would really cut my power down... i've got a bunch of ideas and a lot of maintence and checks to run now... but i'm still open for ideas.... my hope (i hope because i don't know how much time i'll have this winter) is to gut the bike... and maybe run new wires where needed or maybe even the whole wiring harnes...
other things i forgot to mention with maintence i have already done:
new battery (charged and trickle charged at least once per month)
new positive connection coming off the terminal for my main positive power wire
had to run a new wire to the brake/tail light because all positives behind the seat were dead (other than the turn signals)
replaced fuses
replaced headlight (ha ha... i know... shouldn't have anything to do with it)
i installed a LED light on my tach cuz it was out.. (my speedo lights up stock green and my tach lights up blue)
essentially... lots of electrical... and i already know there is more to do... but i've been riding it just fine untill it suddently lost all its power... i have been riding sparingly since the power loss...
in the mean time... keep feeding me ideas guys!!!
1981 KZ750 LTD H2
- soccerd31
THANKS!
1981 KZ750 LTD H2
- Vter Bob
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
- BSKZ650
soccerd31 wrote:
VTR BOB!!!! YOU'RE BRILLIANT!!!!!..... #4 isn't firing... dropped some water on the pips after i fired it up!!..... sooo now all i gotta do is have fun with my electrical system..... YAY..... but its #4... i have my old plugs... and i tried 2 of them.. and... its not the plug.. its the wiring....
THANKS!
- Vter Bob
ROFLMFAO! :woohoo:
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
- baldy110
- Thank you received: 512
