Double valve spring \"interference\"
- BARNEYHYPHEN
20 Mar 2006 09:27
1976 kz900. lapped the valves a couple of weeks ago and reassembled using new seals. When reassembling, I used some newer outer springs as they had a little more height to them.
However, noticed that a couple of the inner springs were a very slight interference fit inside the outer springs. I could push them in just using my fingers but wondered if it could be a problem that these inner & outer springs will rub togeter?
Thanks.
Thanks.
- APE Jay
Re: Double valve spring \"interference\"
20 Mar 2006 12:15
Never seen that on a KZ900 oem spring. Ususlly the inners fall right thru. Aftermarket performance springs usually are interference fit.
Jay
Jay
- BARNEYHYPHEN
20 Mar 2006 12:43
Jay,
It was only the outers I replaced so maybe they were indeed aftermarket? However, from your reply, it sounds as though I'm going to be ok with the little bit of interference I've now got.
Thanks.
Thanks.
