Ottawa Canada Valve Shims help
- KZ1100 Bully
I got the Valve cover off already but really don't want to do it with out some help to show me how to do it.
Bike in heated garage for the winter already.
If you can help me great, send a pm and we can set a time that is good for you.
1983 Kawasaki KZ1100 Spectre D2
- 9am53
- homebrew, and some bbq
- Thank you received: 3
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- Thank you received: 2098
- KZ1100 Bully
- 9am53
'84 GPz900r
'71 CB350
- KZ1100 Bully
Looks like I will have to go it alone, hope fully it not to hard.
- timebomb33
Sometimes the existing gaps are okay, whereby no shim replacement is required.
Other times, maybe just one shim, or only a couple of shims, needs replacing. Typically, the gap reduces with engine wear, so that a thinner shim is needed to regain the desired gap.
Removing the sparkplugs makes it easier to hand rotate the crankshaft when pointing the cam's high part away from the shim (the cam's position when gap is measured with feeler gauge).
Use a 17mm wrench on the fake nut under the points cover to hand turn the crankshaft. That's what the 17mm nut is designed for. And always go forward (clockwise) same direction the engine spins when running.
When attempting to hand-rotate the crankshaft, NEVER twist the smaller 13mm bolt head seen at end of the crankshaft.
Write down the valves' clearance measurements for future reference, and let us know what they are.
If there's any oil seepage onto the cylinder fins, now might also be a good time to replace the cam cover gasket, possibly also the half-moon end plugs, and maybe the tach shaft seal.
Good Luck!
- KZ1100 Bully
I need to order the feeler gauge from Z1. I need to save up for some tools. I also need a cam chain breaker. I know I know but I don't want to take engine out of frame and split the case. I have the chain already just need to tool.
Thanks for the help, I will try.
Carbs were not as hard to do as I thought changed jets and moved needles in 30 min.
- timebomb33
why do you need to split your chain it's not part of a tune-up.
I concur with tb.
Routine valve adjustments do not involve dealing with the cam chain.
After reassembly following valve clearance checking, and any needed shim replacements, might then want to perform whatever routine cam chain tension maintenance is specified for this particular bike.
Good Luck!
