- Thank you received: 337
750 Twin Rubber Fin dampers: use 6 or 8?
- bountyhunter
11 Oct 2009 14:06 #326832
by bountyhunter
750 Twin Rubber Fin dampers: use 6 or 8? was created by bountyhunter
The 750 twins have the small round rubber vibration dampers in between the vertical fins on the head just above the spark plugs. I have one rubber left on each side, so I was going to order new set.
QUESTION: I see four gaps between the five fins, so why does the parts drawing only show three rubbers on each side?
Shouldn't there be one in each gap?
Another question: do they actually do anything you can feel?
- will61310
- Thank you received: 6
11 Oct 2009 18:25 #326875
by will61310
...1980 LTD 1000...
Replied by will61310 on topic 750 Twin Rubber Fin dampers: use 6 or 8?
I believe they reduce the amount of vibration in the handlebars from the harmonics of the engine. Maybe there is another purpose, but i wouldnt know..
...1980 LTD 1000...
- bountyhunter
11 Oct 2009 21:11 #326936
by bountyhunter
Replied by bountyhunter on topic 750 Twin Rubber Fin dampers: use 6 or 8?
I guess I should get some. Still can't figure out why they use three when there are four gaps between fins....?
- PLUMMEN
- Thank you received: 104
11 Oct 2009 21:15 #326938
by PLUMMEN
Replied by PLUMMEN on topic 750 Twin Rubber Fin dampers: use 6 or 8?
find an old junker tow truck that has an old sling on it and cut off a chunk of it,then you can make all of em ya want! :laugh:
- chance
- Life long biker/
12 Oct 2009 04:02 #326994
by chance
Replied by chance on topic 750 Twin Rubber Fin dampers: use 6 or 8?
Because 2 isn't enough and 4 is to many
