Mystery Camshafts
- Oldz1guy
- Still Crazy After All These Years
Just wondering if anyone is familiar with these cams? Made in USA is stamped on them by the cam gear mounts. Part number on edge of cam 45 47015 and 123 7065. Looks to be 405 lift.
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...parms=tab%3DWatching
Ohio Brad
- APE Jay
- Banned
- Thank you received: 58
- larrycavan
- Visitor
That would make sense also. Look at the exhaust cam. Definitely less duration than the intake.
065 cam - .438/258@.040" [intake]may possibley have 1.090" base circle.
015 cam - .410/250@.040" [exhaust]
Not drop in cams. Make a nice set of cams for 1197cc motor for sure.
Too much for anything under 1075cc for street use IMO.
That exhaust cam would also help out if you have over size intake valves. TDC Overlap lift & duration on 015 cam gets the exhaust out of the way.
Every cam grinder in the business could learn from Megacycles application chart. It is THE BEST chart I've ever seen for making grind selections.
Larry C
- PLUMMEN
- Thank you received: 104
- Oldz1guy
Brad
- nads.com
- Thank you received: 20
These were "supposedly" measured with a micrometer at 405 lift. I need cams for my rebuild but my pistons are only 1015 wiseco 10:25 to 1. Any suggestions??
Brad[/quote It's likely there are .407 lift. If they are it's old norris cams or megacycle's (who bought them.) It's easy to be off a couple thou with a digital mic. If they are .407 then they spec out to 280deg.@ .020 lift and lobe centers are 110deg. Running clearance is .006. They have great torque and good duration for a 1015cc. I have these in my bike and the first time I mic'd them I came up with .405 by accident. Mine say kh-259 on them wich may be a core number. The lobe your cams look identical as far as ramp profile and width. Could almost swear i'm looking mine.
- nads.com
- APE Jay
- Banned
Jay
- larrycavan
- Visitor
If your head is flowing mid 80's at 10" and you have some good carbs, you'll have a hot little 1015 motor to run around with.
Look close at the photos, you can see the cams are not the same so that .405 measurement for lift is probably not accurate.
If the price doesn't get bumped up, they're worth snagging..
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
