one tooth off
- lemo32
- The Price of Cool aint cheap
one tooth off
19 Mar 2006 18:16
just went back and checked everything and found i was one tooth off on my exaust, which put me one tooth
of on intake. i got good readings on three of the four cylinders now but one is still low about 95 to 120,
rings looked good, so i think it must valve. Could incorrect shim size throw off compression? thinking of replacing valves on 1 cylinder? poured gas in port
and didnt leak down, kinda got me puzzled.
getting closer every day!
1979 kz 1000 06 katana 750
- wireman
Re: one tooth off
19 Mar 2006 18:24
check valve clearances first,valves hanging open or not opening definately affect compression.goodluck,happy wrenching!
- RomSpaceKnight
Re: one tooth off
20 Mar 2006 15:05
Did you run the bike one tooth off. I slightly bent 2 exhaust valves by doing the same thing. If you do not have enough clearance while cold, when motor heats up clearance could go to nothing and actually hold valve ever so slightly open.
- lemo32
Re: one tooth off
20 Mar 2006 16:32
thats good to know thanks. finally got some compression babe, now its all just a hop skip and a jump. sometimes ya gotta break stuff to fix it
