kz650 wont run unless choke fully on
- paulstanely45
- 1977 KZ650-B
08 Oct 2009 20:45 #326313
by paulstanely45
1977 KZ650-B
kz650 wont run unless choke fully on was created by paulstanely45
Hello,
The last few days I have been having a problem with my bike.
Bike in question. 1977 KZ650B. I have pod filters on it and bigger jets.
The temperature around here has been hovering between 0 and 5 degrees Celsius (32 to 41F).
I can get the bike started (despite having to crank it for almost 20 seconds sometimes), but I can ride for 20 minutes with the choke all the way on, but the second I take it off even a little bit, the bike dies, or if it doesnt, I have not nearly enough power to get me moving.
I had the carbs cleaned and synced this year. Everything had been working perfectly up until recently.
The points are still in brand new condition, I have brand new coils, wires, and plugs on.
Does the temperature have something to do with this? Is there water in my gas tank maybe?
Any ideas would be great. Thanks!
1977 KZ650-B
- timebomb33
- Thank you received: 10
08 Oct 2009 20:48 #326314
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic kz650 wont run unless choke fully on
drain the gas out of your carbs if there is anything wierd in them you will see it if you put a bowl under the drain lines. it sounds like something is plugging your pilot jets or passages.
- paulstanely45
- 1977 KZ650-B
08 Oct 2009 20:53 #326317
by paulstanely45
1977 KZ650-B
Replied by paulstanely45 on topic kz650 wont run unless choke fully on
That is a likely possibility I suppose! I neglected to put an in-line filter in!
1977 KZ650-B
- timebomb33
08 Oct 2009 21:05 #326322
by timebomb33
then it could be happening my little drag bike has a seam in the fuel tank that has developed some rust i use russel fuel filters in line but they can't get every thing after about 4 passes i have to pull my carbs and clean out the rust particles that have gotton thru.it does the same thing as your describing. fixing the tank this winter by the way.
- paulstanely45
- 1977 KZ650-B
08 Oct 2009 21:46 #326327
by paulstanely45
1977 KZ650-B
Let us know how the tank fix goes. I think Im going to have mine cleaned out professionally.
I just pulled off the carbs, and took of both the main and pilot jets. There is some sorta light blue-ish crystals clogging everything up real good. Ill make sure to clean it up real nice, hopefully all good after that.
1977 KZ650-B
- timebomb33
08 Oct 2009 21:58 #326328
by timebomb33
i figured it was something like that drain your tank completly and see if you can find the cause. goodluck.
- baldy110
- Thank you received: 512
12 Oct 2009 11:00 #327061
by baldy110
Replied by baldy110 on topic kz650 wont run unless choke fully on
Did this problem come up after you put on the pod filters and bigger jets?
- paulstanely45
- 1977 KZ650-B
12 Oct 2009 11:48 #327070
by paulstanely45
1977 KZ650-B
Nope, the bike ran fine for weeks.
When I got the bike the jets had been upped but someone put on the stock breathing element, so I figured since the big jets were already in there, I might aswell put on the filters.
But it did run just lovely for weeks.
1977 KZ650-B
- spudbudy
- Kick it like you mean it
23 Oct 2009 15:35 #329178
by spudbudy
78 KZ 650B2. Vetter faring, Dyna S, Dyna Green coils, WG coil mod,AGM Battery, VM26SS carbs, Pilot jet 15, mains 110, jet clip #2 shimmed position, Modified stock air box, stock air filter, Kerker 4 into 1 with stock baffle. currently 48,785 miles. and climbing daily.
Replied by spudbudy on topic kz650 wont run unless choke fully on
Well i ride when it is that cold here I don't have pods but have 17.5 pilot jets works fine
