Hollow sound, top end. Lack of oil? Rubbing?
- Sweet Back
07 Oct 2009 08:08 #325997
by Sweet Back
Hollow sound, top end. Lack of oil? Rubbing? was created by Sweet Back
Strange title, I know. Strange happenings. SO, after having idle problems, a sound developed in the top of the motor. It made the motor sound hollow, as if there were no oil in it. I knew there was, had put in new oil and filter. But I dropped the pan anyway. Found a half a piston ring. We all decided it had been broken from installation. So off somes the head and jugs. Rings replaced, new gaskets. Motor goes back together. Still this hollow sound. Now, as of yesterday, I've dropped the pan and replaced the oil pump as I had a working spare. I haven't put her back together yet, but the old pump really looked good. No crud, sprocket good and so on. One thing I noticed when I pulled the head, was that on the #3 intake cam lobe, there was no pool of oil as in the other lobes. I'm wondering if this could be the culprit, and if so, because I only play a mechanic...where the F does the oil come in for that, so I can see if something is clogged...OR...suggestions are welcome.
- BSKZ650
- Thank you received: 14
07 Oct 2009 09:28 #326007
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Hollow sound, top end. Lack of oil? Rubbing?
umm ,,what kind of bike are you working on?
- Sweet Back
07 Oct 2009 10:04 #326012
by Sweet Back
Replied by Sweet Back on topic Hollow sound, top end. Lack of oil? Rubbing?
Thought it was in the signature, my bad
1993 KZ1000 police
1993 KZ1000 police
- PLUMMEN
- Thank you received: 104
07 Oct 2009 14:55 #326050
by PLUMMEN
Replied by PLUMMEN on topic Hollow sound, top end. Lack of oil? Rubbing?
pull the lifter/bucket off the spring area and look down the hole
- kawsakiman
- Thank you received: 6
07 Oct 2009 16:27 #326062
by kawsakiman
Replied by kawsakiman on topic Hollow sound, top end. Lack of oil? Rubbing?
if you don't replace the two oil pump o-ring gaskets you will lose oil pressure.
- mark1122
- Keep twisting it
- Thank you received: 109
08 Oct 2009 12:13 #326194
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Hollow sound, top end. Lack of oil? Rubbing?
there should not be a pool of oil in there. the drain hole may be pluged.
the oil comes up through the cam bearing, seeps out around it ,then drips down to oil around the bucket.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
