Oilpan swap?!
- letthegoodtimesroll
Oilpan swap?!
19 Mar 2006 14:38
I went to buykawasaki.com and checked the part #'s for the oilpans of the KZ650 and KZ750 and they are the same. Will the oilpan from a GPZ750 bolt onto a KZ650? I have an oilcooler from a GPZ750 and am looking to install it on my bike. Any help in this would be greatly appreciated!
1977 KZ650C1, Kerker Header, Dyna ignition and coils, GPZ 750 oil pan and cooler
- Mark Wing
Re: Oilpan swap?!
19 Mar 2006 14:54
Yes and then you can use the GPZ oil cooler. Either leave the oil level sending unit unhooked or make a block off plate for the hole.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
