valve cover gasket
05 Oct 2009 16:11 #325703 by keith1
valve cover gasket was created by keith1
where the original ones rubber?.....thanks
05 Oct 2009 17:25 #325711 by roy-b-boy-b
Replied by roy-b-boy-b on topic valve cover gasket
No. Roy
05 Oct 2009 17:50 - 05 Oct 2009 17:56 #325717 by keith1
Replied by keith1 on topic valve cover gasket
thanks Roy,....all i wanted to know.....then again......
Last edit: 05 Oct 2009 17:56 by keith1.
05 Oct 2009 17:52 #325718 by timebomb33
Replied by timebomb33 on topic valve cover gasket
that was short and sweet.
I THINK MY POWERBAND BROKE
05 Oct 2009 17:55 #325720 by keith1
yeah it was...now what is the best coating to put on one so
it seals, but yet i can re-use, or at the very least, cut down on scraping the old one off?......
05 Oct 2009 18:03 #325722 by timebomb33
don't put anything on it no sealer is needed. if you want to make it so that you can reuse it dab a bit of grease on the gasket surface then it wont stick to the head or valve cover.
  • ArthurGoVroom
  • I'd rather ride it than shine it
05 Oct 2009 19:11 #325736 by ArthurGoVroom
Replied by ArthurGoVroom on topic valve cover gasket
Make sure you make it so it releases from the cylinder head, because you might booger it up with the prybar and such that comes with the valve shim tool kit.
1976 KZ900A4, 4-1 header, rear lowering kit, grab bar removed, still shining and painting parts as time permits
05 Oct 2009 20:03 #325744 by roy-b-boy-b
When i reuse a very old cam cover gasket i use schellic. A very old school product.
I coat one side and the next day turn it over and coat the other side. Roy
07 Oct 2009 16:56 - 07 Oct 2009 16:59 #326064 by darmahsd
Replied by darmahsd on topic valve cover gasket
Stick it to the cam cover side. Spray the cam cover side with Permatex copper gasket sealer and lightly grease the head side. That's how I re use mine.
I like my aluminum Klasmo cam end plugs. A worthy investment.
Stephen
Last edit: 07 Oct 2009 16:59 by darmahsd.
07 Oct 2009 18:03 #326075 by keith1
thanks for the tips....i dont mind buying a new one, but if i can get it to stick to cover, i can work that on bench and not have to scrape head and worry about droppings...B)
07 Oct 2009 18:11 #326077 by RonKZ650
Replied by RonKZ650 on topic valve cover gasket
There's differing views on this as with everything. The way I've done it is to put a little Yamabond #4 or equiv, on the top of the cam end plugs extending just a little ways out onto the aluminum. This makes sure your end plugs are sealed to the gasket and the gasket if you're careful will stay on the head where you want it and stay aligned. The differing of opinion is if you want the gasket to come off with the cover or stay on the head. Taking it off with the cover most likely it will snag on the top idler sprocket ruining it. Chances of ruining it with it stuck to the head is minimal if care is used, so that's my advice, keep the gasket on the engine and remove the cover. I reuse gaskets indefinately this way. Guys that have valve cover gaskets leak must really have some bad luck or do something really wrong as I've been known to tear a gasket in two, stick a glob of Yamabond #4 on the tear, reuse it and it still seals fine every time.
07 Oct 2009 18:24 #326080 by keith1
that yamabond or its new equivalent works great....3bond 1194 or something like that...i use it on my end plugs ....i have one of those vdo oil press guages i bought on ebay, thing leaked at every connection no matter how much i tightened them...took it apart , put the 3 bond on all connections and not a leak since...put it on th rear cyl studs after i cinched them down as per manual....not a leak anywhere with that stuff....best stuff i have ever used
for oil retention and sealing....thanks for input....
