- Thank you received: 1
Main Bearings and Con rod Bearings for an 810
- Becker
- The Doctor Will Rise Again
01 Oct 2009 19:51 #324968
by Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
Main Bearings and Con rod Bearings for an 810 was created by Becker
I'm rebuilding a 79 KZ 650C motor into an 810, it has 19,000 miles on it and once it was tore down I noticed some dull spots on the main bearings and large end con rod bearings with the conrod bearings being the worst.
So time for questions,
1. Normal wear and tear, or oiling system problems?? I spec'd out the oil pump and its fine but I never checked the oil pressure since the engine wasn't running when I got it. Would 19,000 miles of abuse do this?? Hopefully I'll have pics tomorrow.
2. Do I need to replace them?? Even if they are still within clearance specs. I'm going to be throwing more horse at the bottom end and I'm not sure if these can handle that. or are these things basically bulletproof and I shouldn't worry as long as they are in spec??
3. Where is the best place to get a good deal on these bearings?? At bike bandit I'd be spending 300 or so for the whole shebang. Anywhere else that sells these for cheap??
Thanks to anyone who can help.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- PLUMMEN
- Thank you received: 104
02 Oct 2009 08:17 #325033
by PLUMMEN
Replied by PLUMMEN on topic Main Bearings and Con rod Bearings for an 810
are you having crank checked/polished?
- Becker
02 Oct 2009 08:55 #325043
by Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
Replied by Becker on topic Main Bearings and Con rod Bearings for an 810
I don't plan on having any work done to the crank. is it suggesteed for something like this?? it has less then .0005 of an inch runout and the spec is .0008 of an inch so its in fine condition.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- APE Jay
- Banned
- Thank you received: 58
02 Oct 2009 09:15 #325047
by APE Jay
Replied by APE Jay on topic Main Bearings and Con rod Bearings for an 810
The 650 had soft journal surfaces. Consider having it nitrided.
aperaceparts.com/mailers/crankmail.html
- Becker
02 Oct 2009 15:09 #325090
by Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
Wow, this is getting expensive. but I wanna do it right. the journals are all perfectly within spec. Nitriding is just making it really cold and bring it up to temp slowly right?? It doesn't add or remove material right?? just makes it hard and slippery??
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- DoubleDub
- Visitor
03 Oct 2009 13:06 #325255
by DoubleDub
Replied by DoubleDub on topic Main Bearings and Con rod Bearings for an 810
From my understanding, yes, it is a heat-treating process that hardens the journals to make them more durable. I'm sure ApeJay has the official answer, though.
- nads.com
- Thank you received: 20
03 Oct 2009 15:55 - 03 Oct 2009 15:56 #325276
by nads.com
Replied by nads.com on topic Main Bearings and Con rod Bearings for an 810
Nitriding is heating the crank slowly up to 850 or 950 to preserve the steel's original integrity then it's sprayed with ammonia gas, wich defuses into the surface forming ammonia nitride a ceramic like surface. The new surface is much harder than the original forged steel and has excellent lubricity properties. Crankshafts that have this done will be silver in color between the counterweights.
Last edit: 03 Oct 2009 15:56 by nads.com.
- Becker
06 Oct 2009 13:31 #325848
by Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
Well, I started saving my pennies. I quit drinking (I'm not an alcoholic I just go to the bar every now and then and it adds up quickly). I'm gonna send the crank to Ape for nitriding once I get enough saved up. I'm gonna take this motor slow but I'm gonna do it right. Thanks for your help everybody.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
