Removing the blue and purple from chrome pipes?
- kzrider4life
Current bike..1977 kz1000 1075cc kit,dyna everything,lotsa chrome,kerker pipe.
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
There have been other threads on this subject here somewhere.
West Linn, OR
- chance
- Life long biker/
www.blue-job.net/
- RonKZ650
- Thank you received: 240
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- JMKZHI
- Thank you received: 48
- YUKABODOS
My new pipe has 500 miles on it with only a slight gold tinge. You can hardly notice it.
The bike runs like a champ.
Yukabodos Buddy!!!
:blink:
- MFolks
- Thank you received: 540
- kzrider4life
- JMKZHI
He said "WAY off" - I think maybe he means super rich.So what you are saying is if your jetting is off you will not blue your pipes? Are you sure about that? ...
Excessive heat causes pipe blueing. And MFolks is right about the single walled pipes. What you could try is to load them up on the insides w a heavy oil or grease - coat them good, then run the bike. The theory is that the lube will burn to form a carbon layer that's supposedly heat protective. I have no idea if it really works, though.
- YUKABODOS
SO running too rich and running way lean both can cause overheating issues?
- Tommotbird
Just wondered what actually gets discoloured as it can't be the nickel plating beneath the chrome, and I thought it was the nickel that gave it shiny metal look.
Tommotbird
Triumph Thunderbird Sport
Triumph Legend
Lambretta SX150
Moto Guzzi V11 Sport
1981 KZ650CSR HI
KZ1100 A2 x 4
Z1 Classic
KZ1000 LTD K1 1981
KZ750 LTD H2 x 4
