- Thank you received: 2
ignition housing question
- keith1
27 Sep 2009 17:51 #324364
by keith1
ignition housing question was created by keith1
i stripped out one of the bolts holding points cover on and i m going to replace housing....question is do i have to drain oil or can i just keep bike on kickstand and oil will
stay far enough away?...it looks like seal is at crank centerline and i should be ok.....just wondering....thanks
- PLUMMEN
- Thank you received: 104
27 Sep 2009 17:54 #324366
by PLUMMEN
Replied by PLUMMEN on topic ignition housing question
might drip just a little,put pan under there just incase
- timebomb33
27 Sep 2009 17:59 #324371
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic ignition housing question
you sould be able to work on the ignition housing and clutch as well if the bike is on the sidestand and not lose any oil especally if your side stand has a bit of the kawi droop i work on my clutch all the time at the track and i never lose any oil if it's on the side stand.
- keith1
27 Sep 2009 18:03 #324373
by keith1
Replied by keith1 on topic ignition housing question
timebomb33 wrote:
thanks guys....yeah tim, i put in new clutch and didnt loose crap on kickstand as far as oil....just double checking.......
