Clutch slipping under hard throttle - help
- YUKABODOS
25 Sep 2009 08:39 #323828
by YUKABODOS
Clutch slipping under hard throttle - help was created by YUKABODOS
KZ 650 B2 with a K&N Filter and V&H MegaPhone 4 into 1 with baffel.
So I have completed a lot of work on my bike.
-coil power mod
-carbs synced
-new solenoid
-timing and points adjusted
-new air filter
-new spark plugs
-fresh oil filter
-fresh 10w40 Castrol GTX 4 cycle Oil
It now has a lot more power than it had when I started with it, but now when I am crusing along and I quickly open the throttle the clutch slips. The revs go up and the bike screams like a banshee, but the clutch slips.
What can I do to fix this? I am looking for 2 approches:
Simple fix and a propper fix.
Thanks for your input.
Yukabodos Buddy!!!
:blink:
-coil power mod
-carbs synced
-new solenoid
-new air filter
-new spark plugs
-fresh oil filter
Yukabodos Buddy!!!
:blink:
- Thank you received: 2098
25 Sep 2009 08:43 - 25 Sep 2009 08:44 #323830
by Patton
Replied by Patton on topic Clutch slipping under hard throttle - help
Simple and proper fix would likely consist of clutch push rod adjustment and clutch cable adjustment.
Good Luck!
Good Luck!
Last edit: 25 Sep 2009 08:44 by Patton.
- timebomb33
- Thank you received: 10
25 Sep 2009 08:54 #323835
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Clutch slipping under hard throttle - help
what patton said. if that doesn't work for you then take out your clutch pack and check for glazed or burnt plates and then check those ones for warpage if they aren't warped and you have accessto a bead blaster then blast them and reuse them after a good clean up it gives it a new surface for the oil to adhere to. also if you don't have a beadblaster take a scotch brite pad to them to so the same thing. trust me it will work unless the are warped or measure out of spec you can reuse. all my bikes run used clutch packs
- YUKABODOS
25 Sep 2009 09:19 #323840
by YUKABODOS
Replied by YUKABODOS on topic Clutch slipping under hard throttle - help
Wow thanks dudes for the reply. Anyone have a shot of the shop manual that shows how to adjust the push rod?
- OKC_Kent
25 Sep 2009 10:31 - 25 Sep 2009 10:32 #323855
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic Clutch slipping under hard throttle - help
YUKABODOS wrote:
Go to this page and see if it helps. You may be required to sign up to our little lovefest for 650's.
maintenance.kz650.info/GeneralMaintGuides.htm
Oklahoma City, OK
Last edit: 25 Sep 2009 10:32 by OKC_Kent.
- toadson
26 Sep 2009 08:38 #324051
by toadson
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
Replied by toadson on topic Clutch slipping under hard throttle - help
This may sound stupid, but when you open the throttle is your hand over the clutch lever? The reason I ask is that I used to find myself pulling on the clutch lever just a little bit when I would open the throttle hard, and my clutch would slip. I guess it had something to do with me wanting to hold on a little bit tighter, so I was pulling in the clutch without knowing it. I doubt this is your problem, but thought I would ask anyway!
