camshafts
23 Sep 2009 10:23 - 23 Sep 2009 10:28 #323490 by fcat5
camshafts was created by fcat5
Hi guys, I have a 76 900 and am freshening up the motor a bit. I want to install aftermarket cams. What would be a good size for a basically stock motor? I have access to some cams around .338 exhaust and .347 intake, what do you think?
Last edit: 23 Sep 2009 10:28 by fcat5.
23 Sep 2009 11:51 #323508 by PLUMMEN
Replied by PLUMMEN on topic camshafts
those are small drop in style cams should work fine,are you keeping 26mm carbs?
23 Sep 2009 12:54 #323519 by fcat5
Replied by fcat5 on topic camshafts
yes will be keeping the carbs that came on the bike. Will these cams do anything for me or should i just leave it alone? they are cams a friend had around so i really dont have any paperwork on them.
23 Sep 2009 14:19 #323530 by keith1
Replied by keith1 on topic camshafts
im sure someone else will chime in, but i think stock cams are around .320....i could be wrong on that, but if they are, the ones you have wont make a hell of a lot of difference ....i think anything up to around 380 is a drop in....mine are 360 and even without porting, they arent bad....would be even better with porting....what are you planning on doing for feshening up?
23 Sep 2009 16:41 #323553 by timebomb33
Replied by timebomb33 on topic camshafts
i have a set of .395 lift web cams in my street bike and it rocks but they aren't quite drop ins.
I THINK MY POWERBAND BROKE
  • larrycavan
  • Visitor
23 Sep 2009 19:32 #323585 by larrycavan
Replied by larrycavan on topic camshafts
That's a very mild set of cams. Similar to old 1x Andrews. I would suggest putting them on 106 centers if you do go with them.
Larry C
  • larrycavan
  • Visitor
23 Sep 2009 19:34 #323586 by larrycavan
Forgot to add this pic
24 Sep 2009 06:29 - 24 Sep 2009 06:32 #323619 by fcat5
by freshening up i mean the normal re-ring,new gaskets,and clean the head up a little, not porting just clean it up. The bike runs great now just smokes a little when you wanna run full rabbit. Dont really want big cams just a little bigger than stock. i think they are dale cams or something like that.
Last edit: 24 Sep 2009 06:32 by fcat5.
24 Sep 2009 07:10 #323632 by roy-b-boy-b
Replied by roy-b-boy-b on topic camshafts
If you are going to tear it down it wouldn't hurt to install the cams. Just make sure they have the same amount of teeth on the sprockets. Roy
24 Sep 2009 08:43 #323654 by fcat5
So, would the benefit be worth it for the cams or should i find some a little better? I only want to take it apart once so i wanna be happy with wats goin in it.
24 Sep 2009 08:59 #323656 by keith1
got a lot invested in the ones you have now?
24 Sep 2009 09:59 #323664 by fcat5
no i have bout nothing in them at all. Only thing is ive never really heard of them and its hard to know the exact size?
