Is it or isn't it
- Iron Duke
- what are you rebelling against?
Is it or isn't it
22 Sep 2009 01:51
Have seen engines all chomed up, and have seen the aluminum on clutch, chain, stator, timing covers all buffed out and polished up , can you do the same thing and get the same results on the stock valve covers, are they aluminum, have seen valve covers that look chome but don't think the old Kaws came out with them, Any help ? thanks Duke
1982 KZ550 LTD C-3
1979 XS1100 F Yamaha
- Mcdroid
- Gone Kwackers
Re: Is it or isn't it
22 Sep 2009 03:15
Nothing on the motor, except the starter cover, came chrome from the Kawasaki factory (maybe the KZ1000G1 had some extra chroming, don't recall). Aftermarket, many parts were available chromed. If I recall correctly, the early attempts at chroming were crude and although they initially looked good, would corrode, stain and peel. This apparently had to do with the actual chroming process. Later chroming techniques were greatly improved and the chrome finish holds up much better and longer. With enough effort, aluminum motor cover can be made to glisten like chrome...the trick is owning an electric buffing wheel (not a hand held one), getting a series of polishing compounds (readily available) and practice.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
