Clunking noise in gear box
  • BIGD
  • BIGD's Avatar Topic Author
21 Sep 2009 13:47
#323021
Behind my starter I am getting a clunking noise, that usually happens while idling. There is a metal sounding noise followed by a reduction in rpm, then back to normal. then will repeat itself again, and continue to do so until the bike is underway. Sometimes this will not happen when the clutch is engaged while I am stopped, but not always. The sound is definitely back of the starter, the bolts on the starter clutch have been replaced already. Thanks in advance for any ideas. BIGD
Had 1981 KZ1000 M1 From 1981-1995 Canadian Model
Have 1981 KZ1000 M1 US Model
  • TexasKZ
  • TexasKZ's Avatar
Re: Clunking noise in gear box
21 Sep 2009 14:07
#323027
My guesses would be-
1- Starter clutch malfunction.
2- A loose part or parts swimming around in the clutch (tranny version) area. Something like a pressure plate bolt and spring, perhaps.
Is it a stock or modded bike?
