top end pain
  • lemo32
  • lemo32's Avatar Topic Author
  • The Price of Cool aint cheap
top end pain
18 Mar 2006 15:27
#32274
Heeelllp! I got a new bottom end, well rebuilt that is 900 block bored to 1015 new wiseco pistons, new rings, hand lapped all the vavles, checked for leak down, everything seems fine. i go to set the cams put my pistons on 1, 4, t mark set exaust cam on the little arrow head mark beside the teeth level with head boss mark off 28 pin. 60psi on 1 cylinder 120 on the next, 120 on the next and 180 on 4. when you hold your finger over no,1 its like it blows it out the exaust side, makes a whooshing sound. i had a one piece
head gasket that wiseco sent me. Im thinking this may
be the trouble,do have two piece with o ring.Has any body had head gasket trouble before. or any ideas ?
i dont think i broke any rings but getting ready to tear her down again.
1979 kz 1000 06 katana 750
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
Re: top end pain
18 Mar 2006 15:35
#32277
leaking past the exhaust valve?
crap under shim.
crap between valve and seat when you measured for the shim.
-Duck
  • lemo32
Re: top end pain
18 Mar 2006 15:41
#32280
would you now if you still use the oring with the single piece head gasket?
  • Duck
  • Duck's Avatar
Re: top end pain
18 Mar 2006 15:55
#32286
I have no specific knowledge of one piece gaskets.
I can't imagine needing the O-ring if the one piece
gasket is sealing the mating surfaces around the chain
tunnel. That's all the O-ring is for. Otherwise oil
would leak out between the head and the block.
If you didn't leak air before putting the camshafts
back in and you are leaking air now then I would strongly
suspect that a valve is not seating. Put the air to number
one and listen for the leak.
  • lemo32
Re: top end pain
18 Mar 2006 16:03
#32290
i did squirt a little oil in the cylinder with 60 psi and it did come up to 90. if i could get it em all to be like 4 with that 180 id be flyin two wheeler.
  • DesertWizardB1
  • DesertWizardB1's Avatar
Re: top end pain
18 Mar 2006 17:49
#32349
lemo32, you don't use the o-ring that goes around the center of the cylinders for the camchain if you switched to the one piece headgasket. Most guys fill the recess for the o-ring with high temp rtv or something similiar. There are a few threads here that talk about it. I put a Wiseco 1075 kit on my 1000 and it came with a Cometic 1 piece gasket. I used high temp rtv on mine.
Len
Len
77 KZ 1000 LTD Original Owner
