What head's will fit ?????
- 1977650b1
18 Sep 2009 12:15 #322403
by 1977650b1
What head's will fit ????? was created by 1977650b1
Can someone tell what year 750 heads and cylinders will fit a 1977 b1 650 engine, without going into major mods.
- Mark Wing
- Thank you received: 22
18 Sep 2009 13:10 #322408
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic What head's will fit ?????
Sorry no 750 head will fit with out the 750 crank and cam chain gear. An 82 set of barrels will fit with clearanceing the upper cases. They still have the provisions for the early 650 cam chain gear.
Mark
Mark
Yorba Linda Cal.
- 89LX
19 Sep 2009 19:44 #322590
by 89LX
1977 KZ650B1
Overbored to 66mm in '79 w/ Venolia pop-up pistons & RC400Pro Cams
Restoration in process.....
Replied by 89LX on topic What head's will fit ?????
I had read that '80 to '82 KZ750 heads will work.
I bought a head off e-bay which the seller said was from a '80 KZ750E for use on my '77 KZ650.
I do not have it running yet, but I did mock it up, and it appears to have all of the neccessary provisions to run the 650 cam chain.
Can't speak with any authority on the jug.
1977 KZ650B1
