- Thank you received: 10
dry block
- timebomb33
18 Sep 2009 07:18 #322361
by timebomb33
I THINK MY POWERBAND BROKE
dry block was created by timebomb33
has anybody on here ever done or seen a dry block set-up i'm interested in doing that to my big blocks i'm thinking i'd like to do it cut down on oil seepage around the head and base gaskets if any of you have any info or insight or even wisdom. it would be greatly appreciated.
- Thank you received: 2098
18 Sep 2009 08:47 #322369
by Patton
Replied by Patton on topic dry block
- racer54
- Thank you received: 114
18 Sep 2009 14:54 #322414
by racer54
Replied by racer54 on topic dry block
Timebomb...go over to dragbike.com and do a search. A while back they had an extended discussion on this. Had some tips, ways to stop leaks in different areas, etc. I'll try to find it myself also when I have some time but if you can find it, it will probably answer lots of your questions. If either one of us find it, we should post a lead to it here.
- timebomb33
19 Sep 2009 16:17 - 19 Sep 2009 16:18 #322564
by timebomb33
Replied by timebomb33 on topic dry block
i looked over there and i found some stuff but it wasn't very helpfull most guy's over there had only bad things to say to the guy's that were asking about it beaking off about a certain persons lack off skill in putting engines together i know the guy they were shooting down personally he is a very good freind as well as a fantastic mechanic in fact if i ever couldn't build my own stuff for some reason he would be the guy i would go to. and these guy's just shot him down it was his first turboed big block motor and he was asking legitimate questions which only understandable as there is no manual on how to build these big inch motors is there. it really pissed me off how they go at people over there sometimes.
Last edit: 19 Sep 2009 16:18 by timebomb33.
- kzr750r1
- Thank you received: 9
19 Sep 2009 21:16 #322602
by kzr750r1
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
Replied by kzr750r1 on topic dry block
Seen that happen here too... Your looking for information that some may want to keep close to their chest.
- racer54
19 Sep 2009 21:23 #322605
by racer54
forums.dragbike.com/forum_posts.asp?TID=5793
Go here and it has LOTS of information about sealing a big-block motor.
- timebomb33
21 Sep 2009 10:41 #322994
by timebomb33
thank's racer54 your right it does have a lot of good info and i'm going to try it all these big blocks can be an absolute bear to keep up with mine has so much cylinder pressure then also your dealing with 30+ year old engine castings and close to 50% increase in size they can be over stressed in a hurry.
