- Thank you received: 103
Car oil. Have i killed my clutch?
- roy-b-boy-b
Now i use Rotella. When the formula was changed awhile back i switched. Roy
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- saxjonz
- KawboyZ
- Thank you received: 76
Kawickrice wrote:
I read something somewhere years ago that Castrol GTX was used recycled oil. Is there any truth to this? It really does not matter to me as I have used Castrol GTX 20W-50 for 30 years, from my cars and trucks, to my bikes, to my moped, to my scooter, to my lawnmower, to my generator, to my hand pump oil can in my garage. Never had an oil related problem on any of the above.
79 LTD B3
- saxjonz
- KawboyZ
Once again it may not make such a difference but the big difference is replacing the oil and not being lazy about it. Bad oil is bad oil and can ruin an engine with a quickness.
79 LTD B3
- Buda
I worked at an oil change place about 8 years ago and I saw some weird sh!t with the Pennzoil. Alot of the time when I took the oil cap off there would be yellow foam inside of the oil cap :blink: (foam cant be good). Only the cars that use pennzoil. Valvoline and castrol seamed to look the best.I worked in a fast lube place about 20 years ago and you could tell when a car came in that used Pennzoil. It was always gummed up and had had kind of a sweet smell when you popped off the oil filler cap. Inside the valve cover was always gunked up and the motors all leaked. Since then it's been Castrol in everything I have owned.
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- bountyhunter
- Thank you received: 337
My dad managed a service station back in the early 70's. I remember there was a rap on Pennzoil back then. I believe it was because the viscosity enhancers were parrafin based or some wierd thing and at very high temp they would turn into foamy slime. I think it's OK oil for normal service, but under extreme temps it doesn't work right.donthekawguy wrote:
