cam timing 180 out
  • lemo32
  • lemo32's Avatar Topic Author
  • The Price of Cool aint cheap
cam timing 180 out
18 Mar 2006 09:35
#32205
good morning all.i just set my cams with 1,4 atdc
i got no compression, when i turned the motor over and checked the cams exaust was pointing 180 degrees
opposite to front of head could i have timed on the wrong stroke even though 1 and 4 where at tdc?
1979 kz 1000 06 katana 750
  • steell
  • steell's Avatar
Re: cam timing 180 out
18 Mar 2006 10:05
#32209
You can't time on the wrong stroke (wrong TDC) because the cams determine the stroke (Intake, compression, power, exhaust).
More than likely you used the wrong mark on the cam sprockets.
What model do you have?
ATDC means After Top Dead Center, I think you meant at TDC (I hope so anyway) :)
Post edited by: steell, at: 2006/03/18 13:07
  • Duck
  • Duck's Avatar
  • e vica na i sau na ga
18 Mar 2006 14:08
#32255
Did you get your camshafts swapped front to back?
-Duck
