- Thank you received: 1
Engine cutting out on acceleration from low RPMs
- toadson
15 Sep 2009 22:37 #321925
by toadson
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
Engine cutting out on acceleration from low RPMs was created by toadson
I've noticed an odd problem with my 79 KZ1000 in the past month. Sometimes when accelerating hard from low RPMs (2500 or so) the engine will reach around 3500 RPMs and misfire, almost like a cylinder didn't hit, and the bike will jerk fairly hard. It almost feels like the clutch lets go for a second and engages, but I doubt this is the problem since the engine cuts out. The bike runs fine for the most part, but I notice this problem once out of every few times I ride. It has stock coils, and someone spliced some Taylor wires onto it. I soldered the wires together to ensure a good connection, but I'm starting to wonder how well this setup is really working. I'd like to put some new coils and electronic ignition on it someday, but I am not sure if this is even the problem. Any suggestions on what it could be? Thanks!
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
15 Sep 2009 22:54 #321929
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic Engine cutting out on acceleration from low RPMs
When my coils on my z1 were starting to go out a few years ago i had the same problem. All was fine until the bike warmed up then it would cut out really bad. Perhapse were they spliced into the wires is breaking down? I put in new dyna coils, and i upgraded to the dyna-s over the winter, and it was a night and day difference, along with the wiredgeorge coil mod.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- TeK9iNe
- What did you do!?!
- Thank you received: 28
17 Sep 2009 17:31 #322261
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Engine cutting out on acceleration from low RPMs
I've had this problem as well. It was origional coils too.
New coils and Dyna S like oldkaws4ever says, night and day!
Cheers.
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
