kz550 #4 cylinder not firing
- grandadbob
15 Sep 2009 11:12 #321781
by grandadbob
'83 KZ550 C4 LTD
'06 VFR800 Vtec
kz550 #4 cylinder not firing was created by grandadbob
Can anyone tell me how to check if fuel is getting into cylinder without taking carbs off. I am getting a spark at the plug but haven't checked the compression yet. The bike stood for 18 months and it restarted on 2 cylinders. Eventually #1 came in but #4 is not there yet.
Grandadbob
Grandadbob
'83 KZ550 C4 LTD
'06 VFR800 Vtec
- JMKZHI
- Thank you received: 48
15 Sep 2009 11:55 - 15 Sep 2009 11:57 #321795
by JMKZHI
Replied by JMKZHI on topic kz550 #4 cylinder not firing
You could pull the plug to see if it's wet w fuel.
As for the cylinder not firing, a simple thing to try is to disconnect then reconnect the plug wire at all points from the coil to the plug. The connections become poor from oxidation over time. If the wire appears to be heavily oxidized, you could trim off the wire a tad - not too sort though so that they won't reach.
Last edit: 15 Sep 2009 11:57 by JMKZHI.
- wes_scooter
15 Sep 2009 12:05 #321796
by wes_scooter
76' kz900
70' yamaha R5
2006 wr450f
Replied by wes_scooter on topic kz550 #4 cylinder not firing
does the choke have any affect. or does it go away at like half throttle. your pilot circuit might be pluged up.
76' kz900
70' yamaha R5
2006 wr450f
- grandadbob
15 Sep 2009 12:31 #321799
by grandadbob
'83 KZ550 C4 LTD
'06 VFR800 Vtec
Replied by grandadbob on topic kz550 #4 cylinder not firing
choke has no affect and it doesn't clear at half throttle.
'83 KZ550 C4 LTD
'06 VFR800 Vtec
