Oil Leak Question...
- chrispysaki
13 Sep 2009 19:53 #321456
by chrispysaki
Oil Leak Question... was created by chrispysaki
My 1980 KZ750 is leaking oil near the #3 cylinder header, and I can't quite tell if it's coming from the gasket or from the header.
I managed to reduce it from a significant leak (dripping down onto the pipes and flowing around to the side of the engine) to barely noticeable by tightening the header screws and trying to tighten the engine bolts (they barely moved at all). Last night I added pod filters and rejetted, and today it was leaking a bunch more.
This winter I'm going to take apart the engine and replace the valve seals, gaskets, copper header gaskets and possibly relap the valve seats if necessary. In the meantime, though, I'm wondering if I should have my eyes open to any other specific issues that could be causing the leak.
- mzandmz
13 Sep 2009 19:56 #321457
by mzandmz
New to Family, 1979 KZ440 LTD
Replied by mzandmz on topic Oil Leak Question...
I think adding PODs are your problem,PODs always cause something to go wrong...... I KNOW HER WE GO AGAIN.:laugh: .:laugh: .:laugh: .:laugh: .:laugh: .
- mzandmz
13 Sep 2009 19:57 #321458
by mzandmz
I said it above HERE WE GO AGAIN about POD comment.:dry:
MY BAD.:blush:
MY BAD.:blush:
- Old Man Rock
- Thank you received: 225
14 Sep 2009 04:31 #321502
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Oil Leak Question...
I'm not familiar with the 750 heads so here goes...
On the KZ900/1000's, directly above & slightly off center of # 3 exhaust is your tach drive cable input.... There's seals that will leak if old and hard....
Have you checked to see if this is where the leak is occurring?
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- chrispysaki
14 Sep 2009 10:47 #321566
by chrispysaki
Replied by chrispysaki on topic Oil Leak Question...
I've heard plenty about the pod thing, but I'm not having any issues that would suggest incorrect jetting, so maybe the increase in air/fuel in the cylinder is creating more pressure and is forcing more oil out???
I tried checking the tach cable, but it wouldn't budge. I think I'll need to take the header pipes off in order to get at it. It looks like the leak is coming from below the cable connection, however.
- will61310
- Thank you received: 6
14 Sep 2009 11:53 #321595
by will61310
...1980 LTD 1000...
Replied by will61310 on topic Oil Leak Question...
Well, you had the oil leak before the pods, right? Some people often speak before thinking, as in blaming it on pods...I could not begin to imagine how ones choice of air filtration could create an engine oil leak???:laugh: :laugh: :laugh: :woohoo:
...1980 LTD 1000...
- will61310
14 Sep 2009 11:54 - 14 Sep 2009 11:55 #321596
by will61310
...1980 LTD 1000...
mzandmz wrote:
Duly Noted oh wise one!!I think adding PODs are your problem,PODs always cause something to go wrong...... I KNOW HER WE GO AGAIN.:laugh: .:laugh: .:laugh: .:laugh: .:laugh: .
...1980 LTD 1000...
Last edit: 14 Sep 2009 11:55 by will61310.
- Z1109R Fin
- Thank you received: 1
16 Sep 2009 06:09 #321945
by Z1109R Fin
Z1000R ´83...Slightly modified...
Replied by Z1109R Fin on topic Oil Leak Question...
#3 valve seal on exhaust side leaking. This will run oil into exhaust port and out of exhaust and if you tightened the ex. bolts it seemed to have some effect. Take #3 header off to see if valve stem is oily and whole port in black oil. Just my 2centsB)
- chrispysaki
17 Sep 2009 12:29 #322219
by chrispysaki
Thanks, Z1109R Fin, that was my guess, too, but I know just north of nothing, so I thought I'd throw it out there to see what everyone else thought.
